It sounds like you did not do the brake job personally but had it done by a mechanic, correct?
Your symptoms are similar to those in an other current thread, namely
Front Wheel Wobbly & Brakes Slowing Car? which you might want to read.
Chances are that one of you calipers is sticking. Check to see if any one of the wheels feels like it is dragging more than the others or test drive the car in a safe area and see if any one of the brakes is overheated relative to the others.
Please be cautious and do not drive a vehicle on the roads with questionable brakes. It is unsafe for you and everyone around you.
