Originally Posted by dizwiz24
Is my cat possibly messed up from thousands of miles of burning oil (before engine swap)?
More than likely what happened. The ECU is set to trigger a CEL somewhere around 80% efficiency for environmental standards. That means if you dont feel restriction on the highway, you can drive that way till inspection. suggest not to use aftermarket cats, the ECU is programmed for specific results between the upstream and the downstream 02 sensors. Use of aftermarket cats with more flow and less media "might" produce a CEL in weeks/months time. Might means about 50/50 you have no problem. Expensive odds if it doesn't work out.
Could this be a simple o2 sensor?
about 10% possible its an o2. Can try cleaning downstream o2 with throttle body cleaner, followed by MAF cleaner. DO NOT use seafoam deep creep or any cleaner with heavy lubricant on an air sensor.
