The AC panel indicators and gear shift indicator lamp issue could be just a burned out bulb. If it was a fuse, the other dash indicator lamps, clock, and interior lamps would also be out. You have more fuses under the hood of the car, right by both fender aprons.
3rd brake light issue could be from a number of things - from a bad connection to the bulb itself (corrosion, shorted wiring, etc.). Could be related to the other lamp issues if it is a short (ie, shorting across those wires), but should also have popped a fuse.
Double check the fuse first, do a continuity check on the bulbs to verify if they are OK or not, then it might be a matter of just visually inspecting the wires to see if there are any obvious shorts, damage to the wiring, etc.
