Originally Posted by flynlow3
Question about vvti...This is based of the weight of oil you use correct? I am running mobil 1 15k mile extended performance with a lucas oil additive which runs thicker. Could the thicker addititve be throwing off the VVTi?
I had an OEM one to start with and I ran a Bosch direct replacement. No splicing needed. code did not go away so i picked one up from a guy off ebay who did not use it. Unsure what brand but it to was a direct plug in purchased for 98-02 corolla. The o2 sensor head was slightly smaller than the original one I removed. The bosch o2 sensor had a different head style but it fit.
I did not have to splice either sensor. They were all 4 wire direct plug in units.
I am thinking I have a fuel issue or my timing is off due to oil?
As mentioned in the other post - definitely use a Denso O2 sensor. The small difference in price is well worth the reduction in headaches trying to debug any fuel/fire issue.
VVTi is pretty sensitive to the oil you are running. There is a oil filter associated with the OCV (Oil Control Valve) that can get clogged with particulates and sludge. If that filter is plugged, you can have a lean run condition and/or poor fuel economy.
Personally, not a big fan of Lucas products - maybe they changed the formulation, but they have shown no improvements in performance in almost any engine I've run them in. If you wanted to clean up the donor motor - I would have run a couple of quick oil changes with a good detergent/dispersant motor oil and then settled onto a quality convention or synthetic motor oil.
Additives can cause all sorts of headaches - especially if you are trying to diagnose something at the same time. Some can cause engine leaks, poor oil pressure, too much oil pressure, starve bearings for oil, loosen too much gunk in the engine, and/or foul sensors/sparkplugs.
It does sounds like you have a fuel / fire issue. Vacuum leak could still be a possibility. Damaged wiring from the swap is another.
