adding brake fluid and power steering fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2011, 04:43 PM   #1 (permalink)
View ebc1680's Photo Gallery
I have a 1999 toyota corolla with 102K miles and I see my brake fluid and power steering fluids have reached the -min- level. Should I just buy extra fluids and just top off the canisters or I need to flush each and every tire in case of brake fluid and also flush the power steering.
I had got my brakes changed at 70K miles and dont think they are worn out (else the dealer would have highlighted each time I take in for maintenance). The fluids dont seem dirty however, am not sure if you can do mix-and-match with these fluids or you need entire new fluid.
ebc1680 is offline   Reply With Quote
Old 11-03-2011, 05:39 PM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
The brake fluid level naturally lowers as the pads get worn down (less pad material means the calipers are pushed out, which draws down the fluid level).
It's no problem to top off the brake fluid with new fluid.
As for your power steering, I'd suggest pulling out the cap and dripping some of the fluid onto your hand. If it's dark and thick, you may want to flush the fluid. The correct way to do that is to remove the bolt holding the reservoir onto the frame, pull the two hoses off, and clean the reservoir out with something like brake cleaner. The easier but less effective method is to use a syringe and suck the existing fluid out of the reservoir and fill it back up. You need to do this and then turn the car on and turn the tires left/right a few times to cycle the new fluid through the hoses. It will take several drain and refills to get the fluid clean again.
pdq is offline   Reply With Quote
Old 11-03-2011, 05:59 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $615331
View Zembonez's Photo Gallery
At 102K you should consider flushing and filling both with new fluid. Really good for the long life of the car.
Zembonez is offline   Reply With Quote
Old 11-05-2011, 09:54 AM   #4 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
I would first recheck the condition of the front and rear brakes. Even with age it is not common or good for brake fluid to be at the MIN level. You may have worn brakes or a leak somewhere like the wheel cylinders.
It is really not recommended to top off brake fluid as when the pads are replaced and the caliper is compressed that fluid will pour out of the reservoir and spill all over the place.
Power steering is ok to top off but if brake is at the MIN I would almost guarantee you need a thorough brake check.
hardtopte72 is offline   Reply With Quote
