Replaced my CV shafts a year ago (98 LE 4 spd auto) with a new set by GSP from Advance. Wasn't too happy as there was play in them right out of the box but they seemed a little better than the factory shafts (99k miles), so I used them. Checked today, 7000 miles on them, and the inners, esp on the pass side seems shot. I can swap them out easy enough, but when I grab the inner cup and move it up and down, seems like too much vertical play where the shaft goes into the transmission. No leaking at the seals, but could the bearings inside the transmission have worn? I don't remember how much play there was a year ago, but I don't think this is normal, and am not familiar with the inner components of the transaxle that accept the input shaft. Any experience or advice welcome at this point.
Edit: thought it was a 3 speed but forgot about the O/D button on the shift, so assuming it's a 4. Took the numbers off the trans tag and sticker today but was unable to cross reference to find out the actual transmission model and number of speeds.
Just found this thread, must have been using wrong search terms previously, describes my problem exactly. So I guess the question now is how difficult is the differential disassy? I've done manual tranny's before but always stayed away from automatic. Any info appreciated, thanks.
Half axle to transaxle; should there be play?
