Originally Posted by x2xtreme360
Idk how much I like the compressor running practically all the time in the winter. The extra load all the time.
The compressor will not run all the time, it will only cycle on and off when the evaporator core in the heater box is a few degrees above freezing, much like it does when you run the A/C. The difference is, the ambient temperature is much lower, and it takes very little energy to keep the evaporator cold, and when evaporator temps are at freezing and below, the compressor won't run at all. The added load is negligable, and it has no real and noticable effect on fuel milage. I usually run defrost or blend until the windows are clear (if needed), then switch to floor only. The defrost vents still maintain some flow on "floor only" setting, just enough to maintain clear window in most cases.
As mentioned, the side benefit is it keeps the A/C refridgerent oil circulated throughout the system, keeps the compressor seal lubed, etc.
