98 3spd AT fluid change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2011, 05:16 PM   #1 (permalink)
View laurascorolla's Photo Gallery
My daughter has a 98 with a 3 speed automatic. I was going to change the tranny fluid and filter. It has a regular dipstick, put the haynes manual says to fill using a fill plug on the side of the unit.
Suggestions?
thanks
laurascorolla is offline   Reply With Quote
Old 11-13-2011, 07:55 PM   #2 (permalink)
View dorkiedoode's Photo Gallery
i am a recent owner of a corolla and i filled my car atf using the dipstick. the haynes manual might be talking about a manual car?
dorkiedoode is offline   Reply With Quote
Old 11-13-2011, 08:22 PM   #3 (permalink)
the Haynes manual is refering to a "Automatic transaxle differential" And state " check / fill plug must be removed to check the level, remove the filler plug from the front of the differential".
Are they talking about a separate unit or the AT itself?
Old 11-13-2011, 08:31 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
On a 3spd yes the differential has a separate reservoir filled via a fill plug. For a fluid change you have to do both. Same Dexron III ATF for both.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 11-13-2011, 08:35 PM   #5 (permalink)
^^^ ok, so drop the tranny pan & change filter. Remove differential plug and drain it, fill tranny at dipstick? and refill differential at fill plug? Of refill both from the differential fill plug?
Old 11-13-2011, 09:35 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
Originally Posted by laurascorolla View Post
^^^ ok, so drop the tranny pan & change filter. Remove differential plug and drain it, fill tranny at dipstick and refill differential at fill plug?
This.
Buy my parts
Buy my other stuff
