I have a 98 corolla and wanted to replace the exhuast flange gasket (donut gasket) since I believe it is leaking, causing a slight buzzing sound and sapping some torque during heavy acceleration. I figure I replace the exhaust manifold gasket while I'm at it, since the car is at 145K, it's only $10 part, and it's not like I'm planning to take off the exhaust manifold anytime soon.
So the problem come after I remove the upper heat shield. I see the bolts holding the manifold to the engine block, which are not hard to access and remove. But the two spring bolt at the bottom of the manifold are difficult to access from the top of the engine.
I got under the car and I can access the passenger side bolt of the exhaust manifold. However, the driver side bolt is blocked by the O2 sensor. I can remove the O2 sensor, but it looks like the backet the holds the O2 sensor to the pipe protrudes just enough to block the bolt from the socket getting a good seat on it. The cross member under the car is no help either.
I consulted the Hayes manual but it don't see the backet bolts they are referring to under the car. The manual doesn't even mention the 02 sensor in their removal procedure. Or are they suggesting I unbolt the flex pipe before the catalytic coverter and pull the exhaust manifold and flex pipe from the top of the engine bay.
So I'm a beginner that can change the oils and other wet stuff in the car. I can swap the suspensions stuff, and brake stuff. Even changed the valve cover gasket on this 1zzfe. Plan to keep the car 4ever, which shouldn't be too long since 2012 is just around the corner...but just in case the world doesn't end next month...I need this daily driver in good shape.
Am I missing something? Do I need a really long socket extension to loosen the bolt from the top? Or is there something else I'm suppose to unbolt from the bottom to remove the exhaust manifold.
