Transmission Oil Plug Crush Washer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2011, 08:59 PM   #1 (permalink)
View AnthonyJames's Photo Gallery
I replaced my daughter's transmission oil in her 2002 toyota corolla, LE (auto trans) and purchased a new crush washer. Which way does the crush washer go, small side with 3-tabs in against transmission oil pan, and larger side against plug/bolt head or vise versa? thanks,
The Toyota Part Number is 35178-30010 Gasket, Transmission, $3.63 each, (parts diagram shows part #35106B)
AnthonyJames is offline   Reply With Quote
Old 11-15-2011, 06:48 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167700
View leakyseals's Photo Gallery
I just did that, did not think it mattered, or I got lucky. Pretty sure I put it as you described. No leaks. Don't torque it like a oil drain bolt, will strip it.
leakyseals is offline   Reply With Quote
Old 11-17-2011, 10:32 PM   #3 (permalink)
This is why I don’t go to Vegas….I had a 50-50 chance at getting this crush washer direction right and I blew it….I was wrong. I spoke with two different certified Toyota Mechanics today at the Toyota dealership and they both confirmed the crush washer on transmission drain plug goes: small side with 3-tabs against drain plug/bolt head & larger side against transmission oil pan.
Last edited by AnthonyJames; 11-17-2011 at 10:33 PM. Reason: correct lettering size only
