Clutch Master Cylinder bleeding problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2011, 05:50 PM   #1 (permalink)
View corolla99999's Photo Gallery
Today I replaced the clutch master cylinder on my '99 corolla. when pumping the clutch, the pedal has no feeling and the master cylinder does not get fluid. I don't know why it isn't getting fluid. If anyone can help that would be great. thanks.
corolla99999 is offline   Reply With Quote
Old 11-19-2011, 05:54 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $615331
View Zembonez's Photo Gallery
Air in the system for sure. Did you bench bleed the master?
Zembonez is offline   Reply With Quote
Old 11-19-2011, 06:41 PM   #3 (permalink)
No I did not. The master cylinder is a pain to take off.
Old 11-22-2011, 10:24 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Detach clutch piping from master cylinder. Put finger over opening. Pump. Keep pressure on opening as your helper take foot off clutch. Reconnect piping when you feel brake fluid all over finger. Wipe off any and all brake fluid spilled.
This is how you can bleed the master cylinder without taking it out. When done, move to bleeder plug on slave cylinder and bleed the works.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
