Originally Posted by EdW
With weight in the trunk and 1/2 tank of gas, the bottom of the fender is about even with the top of the (new) tire, so I think it's time to swap them out? Alignment guy suggested it too.
Hmm, I've never checked mine - but I know the rear "looks" like it drops a lot due to the body style. I'd compare that to the free static ride height - 1/4 tank or less and little to no weight in the trunk. If there is a large difference - more than a couple of inches - then I'd say the springs are shot. Check the ride height from each corner, close to the wheels (rocker panel is a good place) and see if there is much difference in height from corner to corner.
When I pull the rear struts and take the springs off, is there any check or test I can do to to assess the overall condition of the strut? They're only a year old but I had odd tire wear on the rears and would like to make sure that didn't do in either strut.
Other than pumping the strut assembly by itself - should resist you pulling and pushing on the strut. Should not be jerky or otherwise uneven in stroke. If it is, try "priming" them. Turn the strut upside down and while keeping it as vertical as possible, push down on it with your body weight several times. This applies to many twin-tube designs (ie most OEM type replacements) - monotubes generally don't respond to this, as they physically separate the oil and gas inside the strut body. Also check the free lengths of the springs and struts - struts should just extend until they hit the top of their stroke, existing springs should be the same height. Just to figure out if they are involved in your excessive tire wear issues.
