2002 Corolla won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2011, 03:36 PM   #1 (permalink)
View Delgado123's Photo Gallery
I got a 2002 Corolla, with 85,000km, turned her off this evening, tryed to start 30min later, and no go, full charge, but not even a click, checked the fuse all good. Is the starter gone?
Delgado123 is offline   Reply With Quote
Old 12-12-2011, 11:13 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167700
View leakyseals's Photo Gallery
Not same car (2002 camry) but same symptoms. Slow turnovers, no turnovers, all symptoms of a bad battery. It was the starter. Probably just the solenoid, but I replaced the whole thing. Used a cheap aftermarket autozone starter because I was left in a bind, been fine over a year.
leakyseals is offline   Reply With Quote
Old 12-14-2011, 11:20 PM   #3 (permalink)
View shui3000's Photo Gallery
check the battery first. if good, check the battery connections, make sure they're tight. if it's not that, check the starter. if you have electricity, but there's no noise when you turn the key, it's probably the starter.
shui3000 is offline   Reply With Quote
Old 12-21-2011, 06:13 PM   #4 (permalink)
View breadbin's Photo Gallery
European Union
twice my corolla wouldn't start, first the key i had cut lost its memory so i tried the original and it worked like a charm, second the engine was flooded due to cold weather and moving the car just a bit and turning it off then. do your wipers come on at all?
breadbin is offline   Reply With Quote
