99 Corolla won`t go into high idle on cold start... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2011, 02:34 PM   #1 (permalink)
View redtherocket's Photo Gallery
The car starts fine, its just not idling high on the first start of the day.
Sometimes it will start pretty rough, but does eventually even out..
I have taken off the throttle body, and the intake manifold and resealed the gaskets.... Torqued to spec..
Checked all hoses, pcv etc... all sealed..
Also cleaned all the sensors with no change...
Which sensor should I be looking at replacingÉ The coolant temp or the MAP....
Anyone with insight would be great.
-1999 Corolla VE
-2010 Ford F150
redtherocket is offline   Reply With Quote
Old 12-28-2011, 08:45 AM   #2 (permalink)
View plncrzy's Photo Gallery
I have a '98 with the exact same problem! .. hoping to find a solution without paying a garage to diagnose + parts + labour = $$$$$$$$$$
plncrzy is offline   Reply With Quote
Old 01-17-2012, 05:58 AM   #3 (permalink)
Thanks for the reply,
I took my C to my local Mechanic with the symptoms (since we had a few more days with -20)... He called me up a few hours later and said "dont you ever use fuel injector cleaner in your car?" .. I said "NO, I thought there was enough additives in fuel these days to do that job" ... he replied " NO WAY!, I just ran combustion cleaner through your engine and could not beleive the black cloud that came out the tail pipe!, you need to run injector cleaner in every other tank of gas you fill"
Car starts and idles perfect since.......
Old 01-17-2012, 06:42 AM   #4 (permalink)
View Jjona5's Photo Gallery
He's crazy, every other tank?
Jjona5 is offline   Reply With Quote
Old 01-17-2012, 07:14 AM   #5 (permalink)
leakyseals's Avatar
Gameroom cash: $167700
View leakyseals's Photo Gallery
So your symptoms were no high idle/sluggish cold start? That was respolved with fuel injector cleaner?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
