The issue with seafoam is that it can damage your cat and 02 sensors.
The huge amount of smoke is from the oil in it( 40 -60 % pale oil).
It smokes whether there is carbon build up or not. Besides the oil thats already in it, you are potentially breaking loose
carbon that does not burn and passes right into your cat clogging it( large amounts of oil dumped into the the cat over a short period can cause serious overheating / melting). I have seen this many times with old and brand new cats ,that were ruined and had to be replaced after sea foaming.
You can knock carbon loose with water( been used for many years) added the same way and its free, though I would not recommend it either.
These methods were fine ( if you were careful not to hydrolock the engine) in the days before 02 sensors and cats.
The only time this needed to be done/ was any benefit, was when the carbon buildup was so bad that it was causing knocking and pinging.
If you are having problems with your engine then fix the real problem.
