Originally Posted by LOLRECONLOL
Hey all,
My car just failed for inspection, with the codes P0446 and P1349 present. The last time (2 years ago) my car failed for these SAME codes, the shop 'reset' the computer and cleared the codes, and passed me. Is this something I could do on my own? My friend mentioned something about disconnecting the battery, then completing a drive cycle. Could anything elaborate on that? Thanks!
Yes, disconnecting and reconnecting battery is a way of resetting the codes. For a day or so will give a emission status of "not ready". The inspection folks will catch on to that, so wait a couple days, a few cold starts, 60+ miles. A few drive cycles. Code P1349 is a VVT oil pressure related issue usually caused by a dirty engine, but can be a bad oil control valve, its filter, or cam gear. Usually accompanied by lifter noise (sounds like a diesel). P0446 is an evaporative system code. Tough to figure out. That could also be a dirty fuel system or may be the Pressure Sensor Switching Valve near the charcoal canister, bad canister, or a few other things.
You have a while to resolve a rejection. Change your oil and filter. Use a synthetic (recommend Mobil 1 High Mileage 5w-30), add 2 bottles of techron complete fuel system concentrate to 2 consecutive tanks (1 per tank), see what happens over a couple weeks. If the lights don't go out, do the battery trick and get through inspection. After that, you should head to a mechanic.
