wheel alignment 2001 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2011, 02:07 PM   #1 (permalink)
View prasadh's Photo Gallery
Question wheel alignment 2001 corolla
hi all
jus back from discount tire center. got the wheel alignment done. pls answer the queries....
queries
1. from the alignment report i find that caster angle is outside OEM recommended range. [ Mine was 2.6 deg in left & 4.2 deg in right. OEM range is 0.6 deg to 2.1 deg both sides]. shop manager says they can not adjust the same. won't this deviation result in tire wear ? shop manager says no.
2. what is the OE recommended frequency for wheel alignment ? [i got in done after a year.is it ok ?]
thanks
prasadh
2001 corolla 124k
prasadh is offline   Reply With Quote
Old 12-31-2011, 03:37 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
The question is why cant the car align to range? The answer is likely a worn suspension part or the car was in an accident. A mechanic can figure that out. Discount tire should have informed you they could not align the car correctly prior to performing the work, told you why they can't, give you the option to refuse the alignment. Because Discount Tire did not tell you what was wrong but took your money anyways you need to go to a mechanic to see whats wrong. If the mechanic replaces a part, will require a new alignment. If I were in your case i would drive and watch the wear. If you start having wear problems seek a mechanic then.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 12-31-2011, 03:46 PM   #3 (permalink)
on full afterburner
Gameroom cash: $1345097
1. Those numbers are way out of spec, take it back to the shop and tell them to redo it. A good quality shop should be able to get it within OEM specs easily unless the cars been in an accident before or parts are worn out like leakyseals said.
2. Usually once a year is enough, but that depends a lot on the quality of the roads in your area.
