99 Corolla chugs when u stop, sometimes! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2012, 05:46 PM   #1 (permalink)
View leopeo's Photo Gallery
I have a 99 Corolla with 160,00 mi., when you come to a stop it will start to chug, it doesn't do it all the time but seems to be getting more frequent. After doing a little research it sounds like it could be the EGR valve or maybe catalytic conv., no lights no codes, looking for a little input. Thank you very much.
leopeo is offline   Reply With Quote
Old 01-01-2012, 06:31 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Is it a vvt-i or non vvt-i? Consuming oil? Usually a chugging or rough idle with no lights can be solved with some maintenance (fluid changes, fuel system cleaner, throttle body/sensor cleaning, tuneup, etc). A vibration will feel different. The whole interior shakes. That can be a bad motor mount. Doesnt sound like your problem
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
The Following User Says Thank You to leakyseals For This Useful Post:
leopeo (01-01-2012)
Old 01-01-2012, 10:15 PM   #3 (permalink)
Thank you for the input, not sure on the vvt-i but will check into and do your suggestions, tune up, etc. Will post how it turns out, thanks again.
