2000 corolla misfires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2012, 04:47 PM   #1 (permalink)
View jamie carter's Photo Gallery
Hey, new to the fourm.
I have a 2000 corolla and I am having a misfiring problem. The car runs fine going highway speed and runs really rough at idle. The codes I got off the code reader are: p0304-misfire on cyl 4, p1300,p1305, p1310, and p1315 wich are manufacture controlled. What does that mean? The pending codes are p0300-random misfires, p0303 misfires cyl 3, p0171 system too lean (bank 1). Any and all help would be apperciated.
thanks,
jamie carter
jamie carter is offline   Reply With Quote
Old 01-04-2012, 05:46 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
What do the codes mean? All your coils may be bad...and your MAF sensor may be bad... Doubtful thats the case so we need to start at the beginning.
How many miles?
When was the last tuneup?
Has any recent repair work been done?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-04-2012, 05:53 PM   #3 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
This could also be a vacuum leak, possibly the intake manifold gasket.
pdq is offline   Reply With Quote
Old 01-11-2012, 10:55 AM   #4 (permalink)
View silverone's Photo Gallery
misfires
hi ill be watching this thread because i am having the same problem.2000 rolla 105k auto overdrive, mine has lean codes random misfires and misfire cyl. 2.(things Ive tried so far)new ngk plugs.,new ignition coil for cyl. 2. When that did nothing I switched #1 coil with #2 had the code puled again and everything was the same. Also dry checked compression it was between 180-185 all 4 cyl. mine runs rough from the tine I start it through highway speeds. Good luck to both of us !
silverone is offline   Reply With Quote
Old 01-12-2012, 09:55 PM   #5 (permalink)
View phantazn's Photo Gallery
this is your problem. fix this, and the misfires will go away.
as pdq stated up above, this is a vacuum leak. start by checking lines under the hood. 90% chance you've got a rotted hose somewhere letting in a lot of unmetered air.
phantazn is online now   Reply With Quote
Old 01-17-2012, 10:05 PM   #6 (permalink)
Well looks like I found my problem check your injectors. A mechanic friend of mine said to swap cyl 2 injector with another cyl. When I pulled it there was a crack down the front .today I went to a u pull yard got 2 injectors for $ 20 bucks PROBLEM FIXED ! Before she
would barely do 70 mph down hill. now she purrs like a kitten.and the C.E.L. is out! p.s. i went through a can of carb spray no vacuum leaks.
