I have no connection on my OBDII port - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2012, 05:23 PM   #1 (permalink)
View preatorian's Photo Gallery
i have toyota corolla zze111 G6R 4zz engine.my problem is that i have no connection with OBDII port.i dont know the reason.
My ecu is bosch oem 89661-0w134
can someone help me if he has the wiring diagram for this ecu?
or some idea how to test the obdii pins?
thank you.
preatorian is offline   Reply With Quote
Old 01-27-2012, 03:48 PM   #2 (permalink)
any help?
Old 01-29-2012, 06:16 PM   #3 (permalink)
View CelicaGuy13's Photo Gallery
Check all your fuses. Make sure there is ground at pins 3 & 4 and 12 v at pin 16. Also with the car running, Use a DVOM to check for varying voltages at pin 8.
Here's a link for the pin out diagram
http://www.2carpros.com/forum/automo...d2_part1_1.jpg
2002 Corolla S
2003 Matrix XRS
CelicaGuy13 is online now   Reply With Quote
Old 02-25-2012, 12:50 AM   #4 (permalink)
just today i check these 4 pins.all work correct but still no connection.
Any ideas?????
i still search for wiring diagram for this model.
Old 02-25-2012, 12:00 PM   #5 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Check for a blown fuse.
ilovecorollale is offline   Reply With Quote
Old 02-26-2012, 12:51 AM   #6 (permalink)
all the fuses are look perfect but until now I have no solution in my problem.
something it must be on the wiring.
something else I have the trip computer only to check liters / kilometre and I have some other radio/cd device so the custom radio is disable. it can be the problem on this ?
Old 02-26-2012, 09:28 AM   #7 (permalink)
Were you checking all the fuses under the dash or just in the engine bay?
Old 02-26-2012, 10:51 AM   #8 (permalink)
both of them.all the fuses in my car works perfect.
Old 02-26-2012, 12:01 PM   #9 (permalink)
Well i guess it leads to what you've done to your car wires.
