98 corolla, 191k, when cold, it makes pinging noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2012, 10:23 PM   #1 (permalink)
View Beekeeper2020's Photo Gallery
After it warms up, the pinging sound goes away.
TIMING CHAIN TENSIONER has been replaced.
Anyone who knows about this issue, what do you do to fix this problem?
Thanks!
Beekeeper2020 is offline   Reply With Quote
Old 01-16-2012, 03:06 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $316765
View Bdub215's Photo Gallery
do you have a video of the sound? i have my suspicions.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 01-16-2012, 03:53 PM   #3 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Pinging would be fuel related. Assuming you mean ticking at startup..most likely the vvt-i cam gear is sticking, problem with the oil filter, dirty internal engine. Don't recommend replacing parts recommend changing oil to synthetic. Should make things better after a few thousand miles.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-16-2012, 04:15 PM   #4 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
If the noise is an engine tapping noise, that's pretty common for this gen corolla when the car is cold.
I've assumed it's either valves needing adjustment or the timing chain bumping against the rails, but never traced down the exact problem.
pdq is offline   Reply With Quote
Old 01-16-2012, 05:38 PM   #5 (permalink)
View irbryanxp's Photo Gallery
1998 didn't have VVT-i.
irbryanxp is offline   Reply With Quote
Old 01-16-2012, 07:14 PM   #6 (permalink)
leakyseals's Avatar
I thought some did. Same issue though, engine needs an internal cleaning
