Lowering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2012, 04:11 PM   #1 (permalink)
TOYROLLA99's Avatar
View TOYROLLA99's Photo Gallery
Talking Lowering
I would like to lower my 1999 corolla. It currently has stock suspension and sits on 17x7inch rims. Right now it sits a little too high for my liking and if I have 3 or more people in the car my tires start rubbing against the strut braces :/ If I could take care of that problem as well that would be great! Any ideas on what brand or type of coil-overs or lowering springs to get? Or if i can even lower it at all and still maintain a quality ride??
Best regards
-ROLLA
TOYROLLA99 is offline   Reply With Quote
Old 01-17-2012, 05:58 PM   #2 (permalink)
on full afterburner
Gameroom cash: $1345097
If you want ride quality stick with lowering springs and struts.
Tein S-Tech springs + Tokico HP struts would be a good combination for your needs.
Old 01-17-2012, 11:44 PM   #3 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
I think you might need a little fender rolling if your gonna drop it down with those 17 inch rims.
ilovecorollale is offline   Reply With Quote
Old 01-18-2012, 12:09 AM   #4 (permalink)
View silverone's Photo Gallery
Can you recomend a good retailer for these for my 2000 rolla thanks
silverone is offline   Reply With Quote
Old 01-18-2012, 01:32 AM   #5 (permalink)
View Jjona5's Photo Gallery
ebay
Jjona5 is offline   Reply With Quote
Old 01-18-2012, 02:44 AM   #6 (permalink)
TOYROLLA99's Avatar
I was worried I would need to cut into the fender. The wheel wells are already pretty small as it is. Maybe I should just try and find some smaller rims, 15inch perhaps. My rims are wider than the factory ones as well so my turn radius is reduced and they rub the strut braces fairly easily
Old 01-18-2012, 02:46 AM   #7 (permalink)
TOYROLLA99's Avatar
I found the struts on autoanything.com for about $115 a piece
Old 01-18-2012, 07:44 AM   #8 (permalink)
on full afterburner
  1. How wide are the wheels?
  2. What's the offset on the wheels?
  3. What's your tire size?
Old 01-18-2012, 02:37 PM   #9 (permalink)
TOYROLLA99's Avatar
  1. The wheels are 7in wide
  2. The wheel offset is 42
  3. The tires are 205/45 R17's the dimensions right now are 23x7 so about 3in on either side of the rim.
Old 01-18-2012, 07:42 PM   #10 (permalink)
i think anywhere with 15 to 16 inch rims that is 6.5 inch or less wide.
Old 01-18-2012, 08:03 PM   #11 (permalink)
TOYROLLA99's Avatar
Yea I think the width plays a big part cuz the strut brace is like RIGHT there, Im going to do some shopping around and see whats out there.
I will probably still wind up getting lowering springs though because ill have a larger wheel gap due to the smaller rims. (I'm still going to want to run low profile tires)
Are the factory struts compatible with aftermarket lowering springs such as TEIN?
Old 01-19-2012, 04:08 PM   #12 (permalink)
yes but the factory struts will die out soon if you use it with lowering springs.
The Following User Says Thank You to ilovecorollale For This Useful Post:
TOYROLLA99 (01-19-2012)
Old 01-19-2012, 07:08 PM   #13 (permalink)
TOYROLLA99's Avatar
I see
Old 01-19-2012, 09:04 PM   #14 (permalink)
on full afterburner
If the wheels rub you might need a minor fender roll and some spacers to push them out further so they clear the struts.
Old 01-19-2012, 09:09 PM   #15 (permalink)
Young Buck
Press22's Avatar
View Press22's Photo Gallery
I've seen people roll on bigger wheel setups.
Roll your fenders and you should be fine.
Like mentioned for ride quality Tokico Blues + Tein S
for more low look into Ksport coilovers.
Mango
Press22 is offline   Reply With Quote
