98 corolla front end grinding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2012, 05:09 PM   #1 (permalink)
View carlos923's Photo Gallery
front end grinding sound when steering wheel is turned left or right. car can be parked or moving. no grinding when car is on jacks and steering wheel is turned, with or without engine running. also grinding sound seems to be coming from passenger side of engine. thanks for any help.
carlos923 is offline   Reply With Quote
Old 01-20-2012, 05:38 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Does this every time you turn the wheel or only sometimes? Tried rotating the tires and see if they still do this? Could be a simple as a screw or similar stuck in the tire.
Otherwise, grinding noise under those conditions - could be anything from a loose or damage tie-rod end, play in steering rack, or loose suspension (strut assembly, rotted bushings). Because the noise is eliminated when the front end is unloaded (in the air) - I'd suspect the tie-rod ends or bad upper strut mounts. If those look out, start expanding the search outwards from those components.
Old 01-20-2012, 05:49 PM   #3 (permalink)
anytime the steering wheel is turned. (only an inch or 2). checked the tires, brakes, rotors. all fine. i will check the items you have suggested.
Old 01-20-2012, 06:05 PM   #4 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Wouldnt hurt to swap the PS fluid, maybe get lucky. Its really easy to do. Also, intermediate steering shafts are an issue with other Toyota's. Listen under and around the steering wheel for squeaks or popping sounds. Could be that.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-20-2012, 06:27 PM   #5 (permalink)
View irbryanxp's Photo Gallery
I had this problem and it ended up being the rack
not a cheap repair! Check to see if your power steering level is low and then take a look to see if its leaking. If it is you may have already done damage to the rack
irbryanxp is offline   Reply With Quote
Old 01-20-2012, 07:33 PM   #6 (permalink)
leakyseals's Avatar
well changing the PS fluid helps the rack thats for sure, maybe you get lucky its easy to do takes 5 mins
Old 01-22-2012, 03:41 PM   #7 (permalink)
had tired eyes, completely missed the problem. was the power steering pump. had no idea they could sound so bad.
