Need some advice... Please!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 12:16 PM   #1 (permalink)
View chad.jordan93's Photo Gallery
My corolla ce has been pretty much Un-driveable. The best way to explain it is just to say it is very sluggish when i first start it up. Then as the engine warms up it starts to run better and better. So I took it to autozone and got them to run a check engine light test, even though it wasnt on. I still got for codes back, p0171, p0110, p0100, p0302. All of these codes go back to air flow issues though.
http://www.obd-codes.com/p0100
http://www.obd-codes.com/p0110
http://www.obd-codes.com/p0171
http://www.obd-codes.com/p0302
after looking at these codes can anyone tell me if it is worth getting fixed ( less then 500)
greatly appreciated!!!
chad.jordan93 is offline   Reply With Quote
Old 01-22-2012, 12:29 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Try this before you go to a mechanic:
1) Change air filter
2) Clean MAF sensor with MAF sensor cleaner
3) Clean throttle body and the IAC hole with the rest of the MAF cleaner
4) Use 2X bottles of Techron concentrate. for 2X consecutive tanks.
That should do it!
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-22-2012, 12:44 PM   #3 (permalink)
View silverone's Photo Gallery
Before anyone could say if its worth fixing, a little more info please. Whats the year, model, the miles on the car? The first thing to do is check for vaccume leaks, with a can of carb cleaner. you are also getting a missfire cyl. 2 have you checked your plugs and wires or coils?
silverone is offline   Reply With Quote
Old 01-22-2012, 12:45 PM   #4 (permalink)
i cleaned the MAF with the cleaner, and the air filter is clean but i will try the other two! thank you for the tips!
Old 01-22-2012, 12:54 PM   #5 (permalink)
2000 corolla with 193000. ill definitely check them out.
I thought it would be good just to get bunch of suggestions all in one place.
Old 01-22-2012, 01:02 PM   #6 (permalink)
leakyseals's Avatar
No problem. The 4 things I gave you worked for me and other people on here with those CEL's. The idea is do all the basics, then move to more complicated (and expensive) items. The techron concentrate fuel system cleaner has PEA, the only known fuel additive that actually works. problems along the fuel system can set off a number of lights, from evap to misfires. the TB IAC controls the startup idle, so between those two something good should happen. Let us know.
Old 01-22-2012, 01:07 PM   #7 (permalink)
leakyseals's Avatar
One more...replace your pcv valve. that should be tired and gooped up after so many miles. when they start to go they can draw oil out the valve, ends up in the air intake, coats the TB and MAF with oil, not good.
Old 01-22-2012, 01:47 PM   #8 (permalink)
I probably do cuz there is oil all over the engine and all the components near it. thank you much, i will try these things for sure!
Old 01-22-2012, 03:14 PM   #9 (permalink)
+ 1 on the pvc you should have seen mine on a 2000 le I just bought, with 105k
Old 01-22-2012, 09:36 PM   #10 (permalink)
View Jjona5's Photo Gallery
Id check the VVT screen also...oil might start flowing through the plugged screen better as it heats up. You might want to check the temp sensor that controls the cold/warmed up cycle on the engine. I'm thinking the VVTI engines have a sensor for the gauge and one for the computer.
Jjona5 is offline   Reply With Quote
