alternator ground wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2012, 06:34 PM   #1 (permalink)
View Akua's Photo Gallery
so i just completed a head gasket change on a 99 corolla.
after removing and reinstalling the alternator, the ground wire-to-battery seems to be missing.
anyone have a picture or diagram of where this wire is supposed to trace back to?
ive done multiple searches but haven't found anything remotely helpful.
any information is much appreciated!
thanks in advance
Akua is offline   Reply With Quote
Old 01-27-2012, 07:05 PM   #2 (permalink)
Bennie's Avatar
Gameroom cash: $110851
View Bennie's Photo Gallery
Not sure exactly which one you are talking about but....
There is a (12"~) 12ga. that goes from the passanger side strut tower to the passanger side motor mount and there are 2 coming off the batter negative post both about 24". One kind of goes to the chassis under the air box on the driver side and the other bolts to the top of the transmission case.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 01-28-2012, 09:43 AM   #3 (permalink)
yea i see all of those. im referring to this one
Old 01-28-2012, 12:01 PM   #4 (permalink)
Bennie's Avatar
Just so you know that is not a ground. It's the +12V alternator output.
It goes to the bottom of the relay/fuse box that is mounted behind the passanger side headlight.
Old 01-28-2012, 01:41 PM   #5 (permalink)
ah ok, thanks a lot for clearing that up!
interestingly enough, the cable is not there??? it pains me that i cant remember how it was connected before i took it off...had everything else labeled but this small part.
Old 01-28-2012, 02:20 PM   #6 (permalink)
Bennie's Avatar
Hope you can find it
Old 01-28-2012, 05:30 PM   #7 (permalink)
yea, me too. the previous owner apparently had done some questionable work with the wiring in this car...
Old 02-03-2012, 05:18 AM   #8 (permalink)
View Jjona5's Photo Gallery
junk yard
Run down to a junk yard and take a peak. Plus if you are missing anything snag it off the car.
Jjona5 is offline   Reply With Quote
Old 02-03-2012, 12:24 PM   #9 (permalink)
yea thats the idea.
well i found where it was, it got lodged between the radiator and core support, it just blended in like part of the harness that runs underneath the core support so i was over looking it. got it all sorted out now thanks for all the information!
