oil on spark plug boot. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2012, 01:42 AM   #1 (permalink)
View phin's Photo Gallery
I have oil at the end of one of my spark plug boot{ 98 corolla].is the seal of
valve cover gasket gone?. The car starts and run fine otherwise. Thanks
phin is offline   Reply With Quote
Old 02-05-2012, 03:21 AM   #2 (permalink)
View KeMBro2012's Photo Gallery
Can't hurt to replace the gasket. I did mine in November and ended up snapping it off in 1 inch strips because it was rock hard. I'm pretty sure it was the original gasket from 99.
There aren't really many other places for oil to come from if it's getting in there; you can get the gasket for less than $20, though I also recommend new hoses for the PCV system and a new PCV valve and grommet, while you're at it. One of my PCV hoses split and the PCV valve grommet disintegrated when I polled the valve off to check it (though the valve itself ended up being fine in my case). The whole job should run you less than $40.
Just be sure to torque the valve cover bolts to 89 INCH pounds, **NOT** foot pounds. I just read a thread about that today. You should be fine using a nut driver (spinner handle) and torquing them all evenly by hand, but I would never RECOMMEND this, always use a proper torque wrench (1/4" drive will typically be inch pounds, 3/8" drive is almost always foot pounds). If all you have is a wrench measuring in foot pounds, you want approximately 7.4 (7.414444444444 to be exact) foot pounds, or 7'5"lb if it has tick marks for inch pounds.
If you have everything you need when you start (just the parts, ratchet, sockets, and torque wrench) the job should take about as long as finding the parts at the parts store.
While you're in there, if you have a feeler gauge, give the valve stem clearances a quick check. Someone else can chime in with what those should be, as I don't have them right off the top of my head.
KeMBro2012 is offline   Reply With Quote
The Following User Says Thank You to KeMBro2012 For This Useful Post:
pdq (02-05-2012)
Old 02-05-2012, 02:43 PM   #3 (permalink)
Thank you for the tips.
Old 02-07-2012, 11:21 AM   #4 (permalink)
View 786audi's Photo Gallery
oil in spark plug area is USUALLY valve cover gaskets. do you have any burning smell from the car?
786audi is offline   Reply With Quote
Old 02-07-2012, 12:24 PM   #5 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Yes that's what it is. Excessive heat over the years has dried the spark plug hole part of the gasket. Right thing to do is replace it - I stopped mine with M1 HM - still should probly replace it though.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 02-07-2012, 12:39 PM   #6 (permalink)
Definitely replace it. Once you have the new (soft, pliable rubber) gasket in hand and start pulling the old one off in rock-hard 1 inch sections, you'll be glad you did.
