Hey guys, quick question...
I put new brake pads and rotors on my 99 a couple months ago, checked the rear drums and shoes, those were almost like new so didn't replace them. Fluid was kinda dark, so I bled everything until new, clean, clear fluid ran from each bleeder valve (one at a time, of course). Braking power seems a bit weak, which I attributed to the new rotors and pads needing to wear in.
2 weeks pass, over 500 miles on the new pads and rotors, only minor improvement. Figure I should try bedding them in;p again only minor improvement. Tonight, 1600 miles later, decide maybe I should bleed everything again, maybe I didn't get all the air out last time. Nope, no more air bubbles, and no improvement.
I know my booster is fine, as it will still be pressurized even after the car has sat overnight or over the weekend. I'll come out and put my foot on the break with the engine off, goes down easily; after a few pumps, it firms right up as the booster loses pressure. However, once I start the engine, pressing the pedal gives a slight whooshing sound as the pedal goes down. Everything feels fine, no squishiness or sponginess, but the pedal does reach the floor if I give it a good push, not even standing on it, just a good push while firmly planted in the seat.
I'm quite possibly selling this car later this week and can't, in good conscience, sell it to the guy without at least telling him what the problem is, if it's the master cylinder. At best, I'd like to be able to tell him "yes, the master cylinder is bad, I'll be replacing to this evening" after tomorrow's test drive, and let him take it for another spin after that. He won't have the cash on hand to buy it until Thursday, anyway.
I can get the part, brand new, for $60 and this won't be the first master cylinder I've replaced (I've done 2 brake and 3 clutch), though it'll be the first one in this car.
Unless, of course, someone wants to (legitimately) tell me that's not the problem. If it's something cheaper (or just labor) to fix, that would be great; if it's something more expensive, good to know going into it so I can get it fixed correctly before I sell it.
That said, I'm asking 1700 for a 99 Corolla with 192k on it, solid engine and trans, new struts and springs 15mo ago with less than 10k on them, that's been running royal purple for the last 13mo and was running redline for the 2yr before that when my coworker owned it. Tranny has had frequent fluid changes, and an additional filter change in November, after my coworker and I determined that the fluid we got out of it LAST November when we replaced the pan (he stripped the drain plug) and filter was the original ATF with 180k on it. Given the condition of the car, it's definitely worth more than 1700, even with a bad master cylinder, and I'm only selling it cheap because I want to buy my coworker's 2000 (manual, I miss driving a manual) and he's asking $2250 but needs $1700 ASAP to pay it off to get the title.
I seem to have gotten a bit off-topic, so I'll move the rest of that though to its own topic. Really just looking for comments regarding the brake issue; anything related to pricing and/or the 2000 I'm trying to pick up, look for my other thread
