White smoke from exhaust for 15 min after start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2012, 01:30 PM   #1 (permalink)
View Asherlane's Photo Gallery
Hi,
My 1999 corolla started blowing white smoke from the exhaust. It is an automatic transmission car with a remote start. The smoke only comes from exhaust and not from under the hood. I recently realized that the engine oil levels are dropping really quick but the coolant levels are fine. There is no overheating problem or anything. The engine is noisy with mechanical sounds of the engine. Also the smoke is there for only 10-15 min after start and then its fine and the engine noise also goes down after 15 min.
Can someone please tell me what could be wrong. I hope its not the head gasket as those things are a real nightmare and expensive to fix.
Asherlane is offline   Reply With Quote
Old 02-06-2012, 01:37 PM   #2 (permalink)
View KeMBro2012's Photo Gallery
Sounds like you've been bitten pretty badly by the piston ring issue that plagues 8th gen Corollas.
What oil do you run? (weight/viscosity and type, petrolium, synthetic, or a blend)
How many miles are on it and how often do you change the oil?
KeMBro2012 is offline   Reply With Quote
Old 02-06-2012, 02:09 PM   #3 (permalink)
Bennie's Avatar
Gameroom cash: $110851
View Bennie's Photo Gallery
Can you give us some numbers on exactly how many miles it takes to burn a qt. of oil? It's unusual that you would see that much smoke. I was at a qt. every 100 miles with one of mine and you could only see a little bit if you floored it.
Is it smoke or steam? Steam would be coolant. Does it smell like coolant (maple syrup)?
It's not just condensation cause it's cold out right?
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 02-06-2012, 05:01 PM   #4 (permalink)
I use Synthetic oil but I changed the oil to a thick version yesterday. There are no leaks of any sort.
Its not the condensation or steam and it doesn't smell like maple syrup. As I mentioned earlier...the coolant level is fine its the engine oil level that is dropping.
I have 180,000 KM on the car.
The smoke only comes out after I start it and continues to smoke for 10-15 min and then there is no smoke after that. In the last 5000 KMs it completely dried up the engine oil...not even a single drop left which is alarming.
Old 02-06-2012, 05:50 PM   #5 (permalink)
if you're having issues related to the faulty design of the piston rings, which often also includes clogged oil return holes in the piston heads, a thicker oil will actually cause more problems for you (aside from the typical increased-wear problems associated with using a thicker oil than specified by the manufacturer)
knowing the weight and viscosity of the oil you were using, and that of the oil you're using now, would go a long way in enabling us to offer you good advice
Old 02-06-2012, 09:23 PM   #6 (permalink)
Took it to Midas mechanic shop in panic a few hours ago and paid them 70 bucks just to inspect
The mechanic took 10 min and said its the valves. The umbrella of the valves are worn out and the oil is going inside the chamber and therefore its burning oil. He then suggested to use Lucas oil stabilizer.
Old 02-06-2012, 09:54 PM   #7 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Thats possible, but unless he took the whole top end apart( the seals are hidden under the valve springs) there is no way to know for sure. It is way more common on these engines to have oil going past your oil rings. Oil smoke has a blueish tint not white. Like what was said above smell your exhaust , you will be able to tell right away if its oil or coolant. Also you can put your hand at the exhaust after its warmed up and if it is coolant your hand will be wet.
sam333 is offline   Reply With Quote
Old 02-07-2012, 01:08 AM   #8 (permalink)
Gameroom cash: $196050
View landphil's Photo Gallery
Adding sand to the engine oil will do the same job faster. In other words, don't put that crap in under any circumstances. Unless you want to finish it off.
If it ran out of oil, is running noisier than normal (damaged bearings, crankshaft...), and is now consuming oil rapidly, it sounds like time for an engine swap or rebuild if you plan to keep the car.
"The thing about quotes on the Internet is you can't confirm their validity"
Abraham Lincoln
landphil is offline   Reply With Quote
Old 02-07-2012, 10:34 AM   #9 (permalink)
I'll second the don't use Lucas. I use their fuel system treatment once per quarter, with a double-dose once a year, but I stay away from everything else of theirs. ESPECIALLY if you're running synthetic, which you should in an 8th gen due to the oil-related issues they seem to have.
Old 02-07-2012, 05:28 PM   #10 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Hi,
If your in alberts canada its pretty cold right? Here in Mass the cars are blowing white smoke sometimes all day. Moisture evaporating from the engine and exhaust in cold weather for 15-20 mins warmup would seem normal to me. Verify no coolant loss????
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 02-07-2012, 05:37 PM   #11 (permalink)
Another thing I just thought of, it could be valve seals letting oil leak down when the engine is shut off.
The seals aren't too pricey and can be replaced without pulling the head, but it's really a pain in the butt job.
Old 02-08-2012, 10:40 AM   #12 (permalink)
You may be right about valve seals. But the mechanics here in Canada are waiting for a customer to come in so they can rip them off even for a tiny job
Old 02-08-2012, 10:43 AM   #13 (permalink)
Not just in Canada. There's a reason the only thing my car sees a shop for is tires and alignment.
Old 02-08-2012, 11:17 AM   #14 (permalink)
leakyseals's Avatar
You need to read This Thread, most likely the problem. Here is another thread showing the fix in detail.
Starving the engine with thick oil, especially in winter is not something you should do. What brand of synthetic are you using and when did you start using it?
Tags
engine noise, engine smoke, white smoke
