flushing the transmission? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2012, 03:10 PM   #1 (permalink)
View 786audi's Photo Gallery
i am about to buy a corolla with 75k 2001 S and the owner says he has flushed the transmission to where all the old one comes out and hes replaced the seals.
i thought flushing was bad for the transmission?
at audiforums people have taught me to never flush the tranny as it will ruin it. shoudl i continue with the purchase or will there be problems later on?
786audi is offline   Reply With Quote
Old 02-06-2012, 09:58 PM   #2 (permalink)
Bennie's Avatar
Gameroom cash: $110851
View Bennie's Photo Gallery
I have flushed a crap load of transmissions and never created a problem. If the transmission shifts good and everything seems fine I wouldn't worry about it.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 02-07-2012, 05:27 AM   #3 (permalink)
View visch1's Photo Gallery
Tranny flush
You omit the type of tranny. I recently purchased a '98 5 speed manual filled with auto trans fluid! Perhaps someone was confused or wanted to give it a flush?
visch1 is offline   Reply With Quote
Old 02-07-2012, 11:19 AM   #4 (permalink)
so what is the difference between a flush and just a pan drop and oil change and filter?
i know the pan drop doesnt remove all the oil but ive also read its much safer for the tranny.
what do they do in a flush?
this is on a 01 corolla automatic
Old 02-07-2012, 11:26 AM   #5 (permalink)
Bennie's Avatar
The difference is simply a 100% fluid change. Also you don't have to drop the pan to do a flush. I'm going to do a write up on a flush shortly here. to sum it up, disconnect a tranny line, start the car and let the transmission pump out the old fluid & replace it with new. Of course that is an over simplified explaination but you get the idea. It's great PM (preventative maint.)
I believe a pan drop only get's about 2.6qt. For a flush I usually use 2-3 gallons.
Old 02-07-2012, 12:00 PM   #6 (permalink)
View KeMBro2012's Photo Gallery
Pan drop on a 4 speed is a a hair under 4qt, a hair over if you pull the filter, as well.
KeMBro2012 is offline   Reply With Quote
Old 02-07-2012, 12:51 PM   #7 (permalink)
leakyseals's Avatar
Gameroom cash: $167200
View leakyseals's Photo Gallery
Just drain and fill every other year, thats it! Almost a gallon. I get my fluid at the dealer. Because the Dex III is hard to find and because they give me a new little crush washer that's also hard to find. This may be important to the OP..anyone/everyone using Dex VI now that dex III is end of life?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 02-07-2012, 12:58 PM   #8 (permalink)
Stick with D-III. The farthest I'd go is to use a DEX-III/IV fluid, never anything that didn't at least claim to be DEX-III. As long as you can still get it from a dealership, or find an aftermarket that conforms to the spec, use it. What it comes down to is the transmission was designed to work with the base oil and additives in DEX-III and using an ATF with a different base, more, less, or different additives, will, not might, WILL lead to excessive wear and premature failure.
