Sticking Gas Pedal?? - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 9 Old 02-19-2013, 08:34 AM Thread Starter
105
Quoted: 1 Post(s)
(Thread Starter)
I'm starting to drive my 02 that I recently purchased and have run into my first problem. I was sitting at a light this morning and when I pressed the gas pedal to go it wouldn't budge. I had to press really hard then it gave way and of course I lurched forward . I haven't taken a real close look at this yet, but have any of you encountered this problem? It could be kinda dangerous.
2002 Toyota Corolla S - 5 speed (previous owner swapped in 04 Corolla motor)
1998 Toyota Corolla VE (A3 --> A4 swap completed 9-30-10) SOLD!!!
105 is offline
post #2 of 9 Old 02-19-2013, 08:37 AM
Super Moderator
heartdisease's Avatar
Quoted: 1899 Post(s)
That is not fly by wire right? It still has a lever or cable? If so something has come loose and is jamming up. If it is fly by wire, which I bet it is, it could still be something jammed. I would look asap you don't want it to stick the other way!
heartdisease is online now
post #3 of 9 Old 02-19-2013, 08:48 AM Thread Starter
105
Quoted: 1 Post(s)
(Thread Starter)
It has a cable and lever just like my 98. It kinda feels like its hanging up on something under the pedal itself. I'm at work now so I'll have to look at it later.
105 is offline
post #4 of 9 Old 02-19-2013, 11:29 AM
Dishin out facts
Quoted: 34 Post(s)
Here some tips: 1) INSPECT YOUR CARPET AND PEDAL. If anything is near it, remove it and test. 2) Throttle cable, clean, inspect, lubricate 3) Butterfly, clean and inspect.
I like to live within my means, and with the least amount of trouble, that's why I LOVE TOYOYTA
BeigeCorolla is offline
post #5 of 9 Old 02-20-2013, 12:20 AM
Quoted: 0 Post(s)
On my sister's Camry the pedal was kinda sticky and we discovered the throttle body was all gunky so we cleaned it and it helped.
2000 Toyota Camry 5SFE Auto 178k Miles.
2003 Toyota Avalon 1MZFE Auto 99k Miles
2001 Chevy Prizm 1ZZFE 5 Speed 162k Miles
dwebb01 is offline
post #6 of 9 Old 02-20-2013, 12:08 PM Thread Starter
105
Quoted: 1 Post(s)
(Thread Starter)
There is some lint and dirt behind the gas pedal on the spring. I pulled some of that out and sprayed it with wd40. It got stuck again today though. When I get more time and a warmer day I'll unbolt it and clean it more thoroughly and take a closer look at some of the other possible causes.
105 is offline
post #7 of 9 Old 02-25-2013, 06:04 PM Thread Starter
105
Quoted: 1 Post(s)
(Thread Starter)
update
Okay, I'm 100% sure its the throttle body. Two times now I've felt the pedal sticking as I'm warming the car up to leave work. Both times I popped the hood and opened the throttle by hand. I really had to put some muscle into it before it would break loose and rev up. I guess the plate is sticking and I need to take the tb off the car and clean it really good. Either that or replace it.
Side issue: I also notice the car idles kind of rough after highway runs (15-20 min to work), so I'm hoping that if I fix the tb problem it will fix the idle problem too.
105 is offline
post #8 of 9 Old 02-25-2013, 10:21 PM
brusk's Avatar
Quoted: 0 Post(s)
Your IAC might need cleaned. I had to clean my TB for sticking and then tear down the IAC as the shaft was seized. Needed to take off the electronics and soak it in PB Blaster for 20 minutes and then spin it then spray it out with carb cleaner. Not sure how these things get so nasty. Mine had what looked like tar build up on it that had to soak in carb dip for about 8 hours before it would come up.
brusk is offline
post #9 of 9 Old 03-08-2013, 06:32 PM Thread Starter
105
Quoted: 1 Post(s)
(Thread Starter)
I beleive I've found the problem. The plate itself was closing a little to far causing it to stick. I turned the adjustment screw 1/8 turn and it seems to be fine now.
You can actually see the yellow mark on the threads of the screw. The mark was towards the front of the car before.
105 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
