How to change the serpentine belt - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 07:45 PM   #16 (permalink)
View OmarR's Photo Gallery
Originally Posted by LoneReefer2005
Is it SPRING LOADED? So I don't have to LOOSEN anything...Just rotate that bolt????
Correct.
OmarR is offline   Reply With Quote
Old 09-27-2005, 11:12 AM   #17 (permalink)
View Spectre's Photo Gallery
I have a quick question.
My wife has a 1998 rolla and I need to change out the Serpentine Belt. This forum is very helpful.
When I loosen the bolt to get the belt off how tight does it need to be when back on? Make the belt as tight as possible or a little slack or is there only one way it will go on? Thanks in advance.
Spectre is offline   Reply With Quote
Old 09-27-2005, 07:20 PM   #18 (permalink)
The bolt is spring loaded, so it provides the automatic tension for the belt. You are not loosening the bolt. You turn the bolt, HOLD IT THERE, and slip the belt off with the other hand. Carefully release the ratchet/breaker bar/whatever you are using to turn the bolt, and it will return to it's original position.
Old 10-01-2005, 09:05 PM   #19 (permalink)
View LoneReefer2005's Photo Gallery
Thanx for advise. I changed my serpentine today. It took about 10 minutes.
I had to remove the splash guard under the motor, to access the belt.
It was a 1 man job.
Thanx forum for the advise on that mysterious NUT that is NOT a NUT! Really a clever, easy system to service. Well done Toyota.
LoneReefer2005 is offline   Reply With Quote
Old 10-01-2005, 09:18 PM   #20 (permalink)
View cashcrazy's Photo Gallery
Funny this topic was at the top of the list. I bought a new belt and plug wires to put on the 99 corolla in the morning.
cashcrazy is offline   Reply With Quote
Old 10-01-2005, 11:06 PM   #21 (permalink)
View GuJu MaN 89's Photo Gallery
is it the same way on a 97 toyota corolla? do i have to take engine out? do i have to remove those 4 top sparkplugs and take engine cover off? thx...
GuJu MaN 89 is offline   Reply With Quote
Old 10-02-2005, 08:40 AM   #22 (permalink)
This is a great forum for advise. Usually I can SEARCH and find my problem.(If search is working)
How 'bout that guy who took a pic of the toyota motor on a stand, showing how to de-tension the belt tensioner. That pic is worth a thousand words. Untill I saw it, I was completely baffled on how to swap out the serpintine.
The spark plugs are even easier to change...They are right on TOP of the motor, as God has always intended. Took me 5 minutes to change, and I used Copper plugs from walmart which cost about a dollar each. Why use 100,000 mile Iridiums when its so easy to change the plugs. Its easier than an oil change!!
P.S. WHat do you mean "Plug Wires?" My 2000 Prizm doesn't use high tension wiring for plugs...wierd.
Old 10-02-2005, 11:45 AM   #23 (permalink)
I mean the spark plug wires. The old ones were still doing fine, but I usually replace the same list of things at 100k I am at 106k. It took me about 5 minutes to change my belt BTW. Thanks for the picture whoever posted it. My little car should be good for another 100k.
Old 10-02-2005, 09:27 PM   #24 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
To change the serpentine belt?
I can guarintee you that you do not need to take the engine out.... but I'm unsure about how it differs compared to the 1zz motor. simply basically turn something and pull it out.. then put the new one in.
I'd have to say though... if you sound this confused.. I'd take it into the dealer
rated_w is offline   Reply With Quote
Old 06-28-2008, 08:52 AM   #25 (permalink)
View byronkarl's Photo Gallery
Any luck with the echo......my daughter's is down and assuming they sold me the right belt...it's not looking good. can relieve tension by sliding alternator but still too short.
byronkarl is offline   Reply With Quote
Old 05-12-2010, 07:53 AM   #26 (permalink)
View Highway_maniac's Photo Gallery
Sorry for using an old topic - I need to picture to explain myself.
In the pic, you see a kind of schock absorber (metal thing with rubber on top, connecting to the tensioner arm and the engine block). Mine is starting to act up (dealer told me so). Got another one, how do I replace it? Can I just unbolt it and bolt on the other one, or do I need to remove the belt first.
Second - the new one has some fluid inside (remove the rubber, you can see it). What is this fluid (oil, special mix of something, glycol?), and how much should be in here?
Highway_maniac is offline   Reply With Quote
Old 01-15-2012, 01:23 PM   #27 (permalink)
View Allen8R's Photo Gallery
Does anyone have a picture waith the belt on? mine broke and came off last night and I can't figure out how to put it back on - the belt I got has a different set of pulleys that my motor and the one in this pic...
Allen8R is offline   Reply With Quote
Old 02-16-2012, 05:53 PM   #28 (permalink)
View crypticlineage's Photo Gallery
Allen8R: This reply is about a month late, and I am sure you have figured it out by now. But just in case, this is how the serpentine belt travels on a 1ZZFE engine:
crypticlineage is offline   Reply With Quote
Old 02-16-2012, 05:54 PM   #29 (permalink)
haha! That really made my day. The Gods at Toyota you mean?
