2000 Corola Transmission Fluid Change/Flush - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 9 Old 12-08-2007, 02:28 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi everone, this is my first time posting here,
I have a 2000 Corolla (automatic transmission) with just about 100K miles on it. I took it to local lube shop to get an oil change last weekend and they came out halfway through and told me that my transmission fluid needed to be flushed for $100. They showed me a swab of my fluid, which was brown vs. new fluid (which was red) and made it sound like this was a serious problem (which I read as them wanting to make a quick buck off of me).
I thanked them for pointing it out but declined the extra service, since then I've been reading about ATF and the various opinions out there about draining vs. flushing and how flushing the fluid on an older car can be harmful to the transmission. I checked my fluid again when I got home and it was brown although it does not smell burnt which I understand indicates serious problems.
So I'm really not sure what to do. Should I have it flushed, drained, or just leave it alone? As far as I know this car has never had any of these done. I've read that if you get a flush you should also get the filter changed (for more $) but I've also read that some (or all?) Toyotas do not have filters but just a screen, how would I know which my car has?
Thanks.
eodabash is offline
post #2 of 9 Old 12-08-2007, 02:45 PM
uʍop-ǝpısdn
rollatuner110's Avatar
Quoted: 1 Post(s)
You should get it flushed. 7 years is a long time. Not flushing it could eat up the gears in the transmission due to the metal shavings in the fluid.
rollatuner110 is offline
post #3 of 9 Old 12-08-2007, 03:46 PM
Feel the vibe.
vibebreaker's Avatar
Quoted: 0 Post(s)
you should get it flushed but not for 100$!
vibebreaker is offline
post #4 of 9 Old 12-08-2007, 04:34 PM
uʍop-ǝpısdn
Quoted: 1 Post(s)
Unless it's flushed with high quality full synthetic ATF like Royal Purple.
post #5 of 9 Old 12-15-2007, 04:08 AM
Quoted: 0 Post(s)
just drain it, almost all fluid can be drained. there is no filter, only a screen there. I took the bottom out and clean it. That is enough.
xzhuang is offline
post #6 of 9 Old 12-15-2007, 10:50 AM
Crowbar911's Avatar
Quoted: 0 Post(s)
I will be doing a tranny drain and refill on tuesday, so i will be making a how to thread with pics for the tranny drain/ new screen/filter. I also have a oil change how to in my camera, and will bet that posted soon too.
Crowbar911 is offline
post #7 of 9 Old 12-19-2007, 04:32 PM
Crowbar911's Avatar
Quoted: 0 Post(s)
I just did my Tranny drain/filter/refill and now my car shifts like a champ. I also did seafoam and it feels great.
I should Have the how-to's for an oil change and tranny drain re-fill with new filter.
post #8 of 9 Old 12-28-2007, 01:15 PM
Quoted: 0 Post(s)
Crowbar: Did you happen to write your HOWTO on tranny flush and oil change?
crypticlineage is offline
post #9 of 9 Old 12-28-2007, 01:59 PM
Beware of pigs
Buurin's Avatar
Quoted: 23 Post(s)
This one?
Buurin is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
