power steering fluid<=>automatic transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 7 Old 07-03-2008, 12:00 PM Thread Starter
greyrolla's Avatar
Quoted: 0 Post(s)
(Thread Starter)
i've been looking around the net and found some boards say you can use automatic transmission fluid (ATF) dexron iii as replacement for power steering fluid.
would substituting the power steering fluid with the ATF not create problems in the long run?
i know it's called ATF for a reason, but why do most boards recommend using it as power steering fluid?
what brand of power steering fluid do you guys use in your rollas?
greyrolla is offline
post #2 of 7 Old 07-03-2008, 12:55 PM
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
Quoted: 0 Post(s)
PS fluid =|= ATF.
Some manufacturer use ATF in the PS, but I've never heard of it the other way around. Ever.
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline
post #3 of 7 Old 07-03-2008, 04:22 PM
Beware of pigs
Buurin's Avatar
Quoted: 23 Post(s)
Some manufacturers spec some very different stuff for the PS. Toyota just happens to spec Dexron III for its PS systems.
Buurin is offline
post #4 of 7 Old 09-05-2008, 11:53 AM
Quoted: 1 Post(s)
Don't mean to dredge up an older post, but is this correct? Does Toyota spec Dextron III ATF for the Power steering fluid? Just curious....I'm getting ready to replace the high pressure hose (leaking at the metal splice in the middle) and just happen to have some Dextron III.
Edit: I just found another post that seems to confirm that Dextron III is listed in the owner's manual. Unfortunately my used 98 didn't come with an owner's manual and I'm waiting on the Service Manuals that I ordered.
Mike
'98 Corolla LE
'98 Jeep Wrangler
'04 Mazda MPV
'04 Ford Thunderbird
mike_tx is offline
post #5 of 7 Old 09-05-2008, 12:14 PM
Quoted: 0 Post(s)
well it depends on how you look at it
Transmission fluid is hydraulic fluid,
Power Steering fluid is also a hydraulic fluid
so transmission fluid is equal to power steering fluid (in the eyes of Ford).
I agree with BigTDogg (MA).
Do NOT put Power Steering Fluid in the Transmission
freeyellow2000 is offline
post #6 of 7 Old 09-05-2008, 12:26 PM Thread Starter
greyrolla's Avatar
Quoted: 0 Post(s)
(Thread Starter)
i am using the Castrol Multi-Vehicle ATF for domestic vehicle for my PS fluid as it is Dexron III compliant. it is reddish in color compared to the old PS fluid which is yellow-brown in color.
post #7 of 7 Old 09-06-2008, 12:04 PM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
Use Dexron III ATF for your power steering, it is what Toyota says to use.
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
