2001 ECU pinout - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 11 Old 04-30-2010, 01:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 2001 ECU pinout
Does anyone have a ECU pinout diagram for a 4spd auto 2001 corolla? am currently installing e-manage and cant find one anywhere!
p.s. this forum is fantastic! so much information, am drooling while looking thru all the post
pyromonkey333 is offline
post #2 of 11 Old 04-30-2010, 01:51 PM
Gearhead
Quoted: 45 Post(s)
There is one floating around - I'll try and find the link.
Also, I'd highly recommend against cutting any OEM wiring leading to the ECM - that is just asking for problems. They make custom wiring harnesses that allow you to tap directly off the connections. A much more robust solution and you can return it back to stock in a snap. Cost varies quite a bit, harness can go as low as $100 or so or as much as $400, depending on who makes it and for what car/EMS unit.
2002 Toyota Corolla S
2003 Toyota Matrix XRS (RIP)
2009 Toyota Matrix XRS
2009 Toyota RAV4 Limited AWD
2016 Toyota RAV4 XLE AWD
fishexpo101 is offline
post #3 of 11 Old 05-01-2010, 06:00 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
hummmm temping fish but no need, luckly ill never revert it back to stock (: my family has owned it since 2000 and ill prob keep the car. when i find another daily driver and give it a few more miles ill most likely strip out the car and make it a track car for the fun of it (:
post #4 of 11 Old 06-16-2010, 11:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
bump? btw am assuming bumping is allowed in this forum
post #5 of 11 Old 06-17-2010, 11:22 AM
Gearhead
Quoted: 45 Post(s)
I ran across this on the NewCelica forum - for a 1ZZ-FE on a Celica GT/MR2 to be hooked to a Greddy Emanage.
http://www.newcelica.org/photopost/d...ageinstall.JPG
I though I had a better copy of the whole 1ZZ-FE ECM pinout laying around, but I haven't run across it yet.
post #6 of 11 Old 06-17-2010, 12:19 PM
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
Quoted: 0 Post(s)
I can check my FSM this weekend. If it's in there I'll take a picture and host it up.
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline
post #7 of 11 Old 06-17-2010, 03:44 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
yay thank you!
post #8 of 11 Old 05-12-2011, 12:15 PM
Quoted: 0 Post(s)
Hmmm...this thread is almost a year old and the post of a 1zzfe ecm corolla diagram pin isnt posted yet...btw the celica ecu is differ from the corolla. i was hoping to find it here but nope...hopefully some one posted it up.
ilovecorollale is offline
post #9 of 11 Old 05-16-2011, 06:07 PM
Quoted: 0 Post(s)
I was curious if the 9th gen corolla has the same ecm pinout with same wiring colors, even though the ecm has a differ set up, as the 8th gen???
post #10 of 11 Old 05-21-2013, 06:28 PM
Quoted: 0 Post(s)
Has anybody found the diagram for the ECM wiring yet?
I need to find out which wire/pin is for the VSS.
Thanks!
jeff88 is offline
post #11 of 11 Old 07-01-2013, 12:38 PM
Quoted: 0 Post(s)
I found this ECU Diagram, but it is definitely an incomplete diagram.
I also found this page justanswer
jeff88 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
« Back
