My car VIBRATES(SHAKES) in idle, its driving me crazyy!! - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 13 Old 07-14-2010, 11:28 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Angry My car VIBRATES(SHAKES) in idle, its driving me crazyy!!
ok so here's the dealio, whenever i come to a complete stop or i am in a red light my car shakes(vibrates) and i can feel it everywhere its bugging the crap out of me, once i press on the gas it goes away! also this happens once the engine warms up, when its cold it doesnt vibrate(shakes)
so far i have cleaned the throttle body, cleaned the pcv valve, the maf sensor, and also inserted a fuel injector cleaner into the tank.
*edit* it is a 2000 TOYOTA COROLLA VE, WITH 81,600 miles
pocketz_)6 is offline
post #2 of 13 Old 07-15-2010, 12:22 AM
Quoted: 0 Post(s)
sounds to me that your motor mounts are worn. when your car is cold it is at a faster idle till it goes into cl and idle will drop hence making your car shake. ive replaced a bunch of motor mounts for corollas for that complaint. gl
toyotatech671 is offline
The Following User Says Thank You to toyotatech671 For This Useful Post:
2004 (07-17-2010)
post #3 of 13 Old 07-15-2010, 01:48 AM
new to TN
ExDream's Avatar
Quoted: 0 Post(s)
for me it was my coil packs.
ExDream is offline
post #4 of 13 Old 07-15-2010, 02:17 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
how can i be sure its the motor mounts or coil packs/spark plugs?
how can i check for these??
as i am college student in a low budget and need to spend my cash wisely lol
post #5 of 13 Old 07-15-2010, 08:16 AM
Quoted: 0 Post(s)
I have a 99 Ce with the problem.
So far i have changed:
all the mounts
Intake manifold gasket
plugs
plug wires
checked for vacuum leaks
no dice problem persists haven't had time to try anything else. would lave to hear anyother ideas
Chinsan is offline
post #6 of 13 Old 07-16-2010, 12:41 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Red face
sooo, no suggestions??????
okkkk thanks thoughh
post #7 of 13 Old 07-16-2010, 03:19 AM
ロンリードライバー
Quoted: 0 Post(s)
1. Buy a Haynes manual if you don't have one. It's only like $15-$20. I'm a Post-Bac Grad now and even I bought one as an undergrad.
2. Look at the mounts. See if they're worn out. Search the forum, there's been some talk about how to look at the mounts.
all2baka is offline
The Following User Says Thank You to all2baka For This Useful Post:
2004 (07-17-2010)
post #8 of 13 Old 07-16-2010, 03:29 AM
Quoted: 0 Post(s)
I gave you my professional opinion, from my 10 years as a dealer mechanic. Dealing with all the issues with corollas from late 90's to early 00's from belt tensioners, leaking oil from head gaskets, cat converters just to name a few. It's that from your description it sound as if the mounts are worn. By any chance did you or someone scan yout car with a toyota scan tool? it has a lot of features that most inexpensive generic scanners don't have. Read the data list and see if all the data in the ECM is within spec. Thats where i would start. Did u reset the computer after you cleaned the mass air flow and tbody, when u clean those componets the computer only remembers what it had learned with all the build up of contaminats like carbon, dirt and the elements of earth,lol. Your computer will relearn after driving it a bit, but will learn new values faster if you pulled the EFI for a few minutes to reset back to stock parameters. All though It could be anything or multiple issues one could never truly know only suggest possibles without actually looking at it. GL and lets us know what you come up with.
2004 (07-17-2010)
post #9 of 13 Old 07-16-2010, 07:27 AM
Vivir el momento
Quoted: 34 Post(s)
Sounds like your engine mounts are done.
PhatRoyale is offline
post #10 of 13 Old 07-16-2010, 10:15 AM
Eat, Sleep, Toyota.
CorollaTRD99's Avatar
Quoted: 1 Post(s)
i had the same problem. if you notice your gas burning a bit faster, it may be a loose fuel injector, it happened to me. to be sure just remove the cover and press on each injector and tie one of those cable things that are used to tie cables together and never come off. loose fuel injectors cause a strong vibration when cold.. thats my 5 cents
'99 Toyota Corolla non-vvt-i
CorollaTRD99 is offline
The Following User Says Thank You to CorollaTRD99 For This Useful Post:
2004 (07-17-2010)
post #11 of 13 Old 07-17-2010, 02:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thumbs up
ok thanks guys, im going to have a mechanic look at my motor mounts
ill update you guys soon, see if the problem persist
thanks for the advise. i appreciate it
post #12 of 13 Old 07-17-2010, 09:40 PM
VVT-1MZ + ES5spd
Bdub215's Avatar
Quoted: 12 Post(s)
and there should've been a code for a misfire right?
well for something that has a 2.5-3 millisecond pulse rate i imagine it would
please do.
93 Lexus ES300 5spd I/E URFSB URRSB
01 Toyota Avalon TFSB, Weapon-R, Whiteline, Fogs
Bdub215 is offline
post #13 of 13 Old 09-30-2010, 11:03 PM
Quoted: 0 Post(s)
compression
do you notice white smoke coming out of your exhaust ever?
If it is a problem with a certain cylinder you can isolate it by taking out a plug
one at a time while the engine is running, and see the difference in operation.
Get a compression check if you are able to isolate your problem to one cylinder.
paul.wipf is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
