Corollas and shaking streering wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 18 Old 08-22-2010, 06:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have noticed most Toyota Corolla's have a problem with shaking steering wheel. My 2000 CE shakes on the highway at about 60-70 mph. My G/F 98 VE shakes really bad from 50 closer to 60. I have balanced tires, had an alignment done. even swapped tired to the rear. Same with hers she had a bad tire rod, replaced it, alignment, balanced tires brand new tires shakes bad.
I am left clueless and post on the forum.
metalmusiclver is offline
post #2 of 18 Old 08-22-2010, 09:08 PM
Quoted: 0 Post(s)
check you rims, a bent or dented rim can cause the shaking, normally if you've done all of those, its going to be the rims causing it
GuardianArchon is offline
post #3 of 18 Old 08-22-2010, 09:43 PM
VVT-1MZ + ES5spd
Bdub215's Avatar
Quoted: 12 Post(s)
could be cheap sets of tires with low speed ratings.
93 Lexus ES300 5spd I/E URFSB URRSB
01 Toyota Avalon TFSB, Weapon-R, Whiteline, Fogs
Bdub215 is offline
post #4 of 18 Old 08-22-2010, 10:53 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Tested bent rims, took the front and exchanged them with the rears.
post #5 of 18 Old 08-23-2010, 10:17 AM
blb
Quoted: 0 Post(s)
I have to disagree with the statement "most Toyota Corolla's have a problem with shaking steering wheel". I have five of these cars ranging from 6th generation to 8th generation and none have a steering wheel that shakes. Cheap tires, out of balance tires/wheels and bent wheels are the most likely culprit. You need to check the wheels for runout with a dial indicator to see if they are bent. Also make sure the wheel bearings aren't shot. Cheap tires that are out-of-round or have bad belts can also cause this problem. Might want to start by having the tires rebalanced. Many tire shops do not periodically calibrate their spin balancers and send many out of balance tires out the door.
blb is offline
post #6 of 18 Old 08-24-2010, 12:47 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
ok It was a coincidence that 2 of our vehicles do it. She has brand new firestone tires and I have BFG's the rims were swapped from front to back. it's got to be in the steering rack or opposing items.
post #7 of 18 Old 08-25-2010, 12:35 PM
Quoted: 0 Post(s)
try my fix
Rear Vibration
good luck
1_grendal is offline
The Following User Says Thank You to 1_grendal For This Useful Post:
2004 (09-08-2010)
post #8 of 18 Old 08-25-2010, 07:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
^ You know I totally thought the axle may be the problem. Both mine and her driver side boots are ripped open and shotting grease everywhere. time for new axles!
post #9 of 18 Old 08-29-2010, 09:15 AM
burnout8488's Avatar
Quoted: 1 Post(s)
My Prizm does this too and it has new tires and a fresh balance. Time to check out the axles!
'07 Camry SE V6 - For Sale!
  • Loaded + SatNav
  • K&N Intake
  • 17" Avalon Wheels
burnout8488 is offline
post #10 of 18 Old 09-02-2010, 10:36 AM
Quoted: 0 Post(s)
not to say anyone is a bad driver, but circumstances come up where you lock up the wheels when your trying to stop. this could leave flat spots on the tires and will cause a vibration and noise. i personaly drive way to hard and use every bit of suspension and tires (and yes i use the e-brake, because it isn't drifting, but it is fun) in turn after about 12k miles my tires a shot, and that last 100 miles while i save up for tires, my steering wheel vibrates like hell at about 55-75, i try not to go any faster than that unless im on the highway.
NoItIsNotACivic is offline
post #11 of 18 Old 09-08-2010, 10:04 PM
Quoted: 0 Post(s)
so you're ok now with new axles? please, i'm waiting for your answer, because i'm having this same problem... thanks!
2004 is offline
post #12 of 18 Old 09-08-2010, 11:26 PM
EdW
Quoted: 2 Post(s)
Can the CV joints be checked when in place or do they have to be removed? What kind of play or looseness should I look for?
EdW is offline
post #13 of 18 Old 09-09-2010, 11:24 AM
Gearhead
Quoted: 45 Post(s)
Usually, you'll have to diagnose a suspect CV joint by listening to the tall-tale clicking or crunching sound. Mostly while making turns, feeling vibrations in the chassis/steering wheel that intensify with acceleration, or in really bad cases, a physical "clunk" when accelerating and decelerating.
Wiggling / turning the wheel in the air will not be able to diagnose a bad CV joint, unless it has some visual clue - ripped boot, leaking grease, etc. There is some nominal "slop" when you turn the drive wheels when the car is in the air.
What you can find out by prying on the wheel in the air - is if you have a worn lower ball joint, bad wheel bearing, and loose suspension bits.
2002 Toyota Corolla S
2003 Toyota Matrix XRS (RIP)
2009 Toyota Matrix XRS
2009 Toyota RAV4 Limited AWD
2016 Toyota RAV4 XLE AWD
fishexpo101 is offline
The Following User Says Thank You to fishexpo101 For This Useful Post:
2004 (09-10-2010)
post #14 of 18 Old 09-09-2010, 12:25 PM
Quoted: 0 Post(s)
This is not a factory defect. I had the whole shaking steering wheel, humming noise, and vibration. I have a 94 geo prizm w/145k miles. Heres a list of things i did.
Replaced my 17's with factory 14's and new tires.
-Replaced a wheel bearing in the back.
- replaced inner and outer tie rods in the front. they were all bad except for one.
-finally aligned .
Car rides good now. There are so many things that can be wrong.
Axles, Struts, Strut mount, Ball joints,Wheel bearing, Tires, Alignment, Cheap rims. Maybe you can take it to a mechanic have them inspect it and fix it yourself.
94PrizmDD is offline
The Following User Says Thank You to 94PrizmDD For This Useful Post:
2004 (09-10-2010)
post #15 of 18 Old 02-24-2013, 09:24 PM
Quoted: 94 Post(s)
hate it when someone doesnt post the results or findings of an issue that will help the community out! total bs
lexusman is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
