Cruise Control not working? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 3 Old 05-14-2011, 03:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 2001 Toyota Corolla LE and the cruise control is not working. When I turn it on a green light turns on that says CRUISE and nothing happens. Once I try to accel or anything using the cruise control the green light flashes.
Thank you for you input!
Scott
sKramer is offline
post #2 of 3 Old 05-15-2011, 08:25 PM
Quoted: 0 Post(s)
Not much help with the Corolla, but I have a similar issue with my 94 Landcuiser. One way people have been able to "fix" it is to lube the cruise actuator that pulls on the cable or adjust the cable. If that doesn't help, then its probaly time for a new actuator.
I've found that on my LC, it will hold at certain speeds better than others. Seems to hold fine at 50, but at 65 it would start that blinking thing you mentioned. The only way to fix it is turn the car off and back on to reset the cruise computer. Sometimes it does this, other times it actually holds for a while. Does yours always blink, or does it work intermittant?
Now, I just recently purchased a 2001 corolla, and the cruise works around 45 when I tested it... but at 70, it doesn't seem to hold.. but it doesn't blink at all either.
'01 Corolla LE (The gas Miser)
'89 Supra Turbo (Blitz Nur Spec, Michellin Pilot Sports)
'94 Land Cruiser (ARB front, Kaymar rear, sliders, lifted and locked)
gbell210 is offline
post #3 of 3 Old 10-10-2011, 06:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Sorry for such a late reply, been kinda busy. My cruise control doesn't work at all. I've tried it at 20 30 40 50 60 70 everything! It just blinks.
sKramer is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
