corolla timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 10 Old 08-25-2011, 10:31 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question corolla timing belt?
I have a 1999 corolla 1.8 with 42000 miles and I want to see about changing timing belt. Talked to a garage close here and he thinks it has a chain and not a belt. Does anyone know for sure if this is the case?
falente is offline
post #2 of 10 Old 08-25-2011, 11:52 AM
Bennie's Avatar
Quoted: 7 Post(s)
It's for sure a chain.
Current DD - '06 Jetta TDI 5 Speed
Bennie is offline
The Following User Says Thank You to Bennie For This Useful Post:
falente (08-27-2011)
post #3 of 10 Old 08-25-2011, 05:22 PM
Vivir el momento
Quoted: 34 Post(s)
Your 1ZZ-FE engine has a timing chain.
PhatRoyale is offline
post #4 of 10 Old 08-27-2011, 11:21 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It has a 22R engine
falente is offline
post #5 of 10 Old 08-27-2011, 11:47 AM
Vivir el momento
Quoted: 34 Post(s)
Originally Posted by falente View Post
It has a 22R engine
I highly doubt that is the case unless the previous owner completed a swap.
All 8th gen (1998-2002) Corollas sold in North America have the 1ZZ-FE.
post #6 of 10 Old 08-29-2011, 06:17 AM
Bennie's Avatar
Quoted: 7 Post(s)
It has a 22R engine
In your first post you stated it was a 1.8. Isn't the 22R a 2.4?
Obviously that doens't add up. You may want to double check things. As stated by PhatRoyale if it's stock it's got the 1ZZ-FE with a chain.
Bennie is offline
post #7 of 10 Old 08-30-2011, 09:12 AM
Quoted: 0 Post(s)
My '99 has 210,000 miles on it and I am just now getting around to changing the timing chain for the first time. So I wouldn't panic if you don't get your 42,000 mile timing chain replaced this week. : - )
A local mechanic told me that getting the timing gears / cogs / sprockets / whatever-they're-called replaced is just as important or even more important than getting the chain itself replaced. That's what I came on here today to ask about, so I will be a good forum member and go post that in its own thread. : - )
StephanieD is offline
post #8 of 10 Old 03-17-2012, 07:58 PM
Quoted: 0 Post(s)
How difficult is it to change the chain? And do u need special tools? Thanks Steve
mrnavy2 is offline
post #9 of 10 Old 03-18-2012, 12:52 PM
Quoted: 0 Post(s)
It has a 22R engine
Really doubt you have a 22r. 22r is 2.2 liters and is carbed.
carnage9 is offline
post #10 of 10 Old 03-18-2012, 02:31 PM
Quoted: 0 Post(s)
Not to second guess you, but the 22R was in things like the old Hilux from a bygone era and never installed (by Toyota) into a modern corolla. Even then it is a chain drive engine, so no timing belt. We see high km 8th gens at work all the time and have never replaced a chain in all the time I've ever worked on them
shawnd is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
