Key broke off in ignition switch! - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 11 Old 07-04-2012, 02:24 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Key broke off in ignition switch!
So yesterday my key just broke off inside the ignition switch. it broke off half way so it is deeeep in there. Cant grab it with anything not even magnet. I took off the plastic covers around the ignition switch and popped out the piece where the key goes in. So now im sitting at the house thinking of ways to get it out.
Please let me know if you guys have any ideas or if anybody had a similar problem. I called a couple locksmiths and they charge from $120 and up. any help will be highly appreciated.
02corollaS is offline
post #2 of 11 Old 07-04-2012, 08:37 AM
Quoted: 0 Post(s)
a dab of jb weld on the unbroken part and stick it back in?
doctorbee is offline
post #3 of 11 Old 07-04-2012, 12:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i was thinking of using a skinier metal piece with jb weld. Im afraid if i put it on the unbroken key it will just get stuck inside maybe?
post #4 of 11 Old 07-04-2012, 12:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
post #5 of 11 Old 07-04-2012, 01:22 PM
Forever Corolla's Avatar
Quoted: 17 Post(s)
Easy fix..
If half of your key is in place, do you still need your other half to start the car?
Great!!!
Leave the piece in place, it is still doing its job.
Use the other 1/2 of the key to start the car and then remove the half a key..
When done driving, use the other half a key to shut it off, take the 1/2 key with you..
You will still have a key!!
Okay, not great.. So, you need a more permanent fix.
Can you slide a thin wire all the way past the key to the bottom?
It needs to be a stiff wire that will hold a very small L shape at the end of the wire.
Slide the L at a 90degree angle all the way past the piece, then turn back 90degrees behind the tip of the broken piece.
Spray the path with WD40 and slowly pull the piece straight back.
Now you need a NEW KEY
Do not put a heavy ring of keys on the new one.
Puts too much pressure on the key and the ignition/lock
Forever Corolla is offline
post #6 of 11 Old 07-04-2012, 08:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The key is all the way at the bottom. Been trying to get it out for 2 days. I will try to use super glue on the other piece of the key and stick it in, jb weld didnt really work. If this doesnt work probably will go to locksmith tomorrow unless you guys have any other ideas.
Does it matter which position the key in. ACC, or Start,
post #7 of 11 Old 07-05-2012, 07:12 AM
Living on a Rock
kaitaiya's Avatar
Quoted: 1 Post(s)
can you get the whole lock cylinder out? you'll need to put it into the ACC position and depress the pin on the top. once it's out you might be able to put it back into the off position and tap the lock cylinder on a bench to see if the end of the key will dislodge.
if not it might be easier to take just the cylinder to a locksmith instead of having one of them come out.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline
post #8 of 11 Old 07-05-2012, 08:57 AM
Quoted: 0 Post(s)
If other options fail:
replace lock cylinder with junkyard unit w/key
replace steering column with junkyard unit w/key
shockley is offline
post #9 of 11 Old 07-05-2012, 01:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes i took out the lock cylinder 2 days ago and been doing everything i can think of. Hitting, trying to glue it, using paper clips and needles, magnet. nothing works, it didnt even move. I guess its up to a locksmith.
How much you guys think is a good price? If its under $100 ill be good with that
post #10 of 11 Old 07-05-2012, 02:19 PM
Living on a Rock
kaitaiya's Avatar
Quoted: 1 Post(s)
If you have AAA+ it's free. Otherwise $60-100 would be fair.
kaitaiya is offline
post #11 of 11 Old 07-05-2012, 03:34 PM
Quoted: 0 Post(s)
Local junkyard says if they had a used cylinder w/key they would want $30 for it. YMMV
shockley is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
Tags
broken key , ignition switch , key stuck
User Tag List
Linear Mode Linear Mode
Back
