How-to Replace automatic transmission filter & Flush Video - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
post #1 of 8 Old 01-23-2013, 03:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So I have been doing a lot of maintenance work on a 2001 corolla and I figured I can video tape to help others who work better with visual aids.
http://youtu.be/R1mds_g3qOE
zran22 is offline
post #2 of 8 Old 01-24-2013, 12:47 AM
Quoted: 1 Post(s)
thanks
e30iwite is offline
post #3 of 8 Old 01-25-2013, 10:59 AM
Gearhead
Quoted: 45 Post(s)
You didn't mention that there is a separate drain and refill for the differential on the 3-speed transaxle as indicated in the video. I also didn't see any flushing in the video - just saw a fluid drain from the transaxle, pan drop, and refill. Unless the link took me to the wrong video.
Also looks like there was RTV used on or as the gasket for the transaxle pan - generally not needed anymore for the current cars, unless your pan is so distorted that it leaks without it. That point, I'd recommend replacing the pan.
2002 Toyota Corolla S
2003 Toyota Matrix XRS (RIP)
2009 Toyota Matrix XRS
2009 Toyota RAV4 Limited AWD
2016 Toyota RAV4 XLE AWD
fishexpo101 is offline
post #4 of 8 Old 01-25-2013, 11:21 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Your right about the alternate fill, but the dipstick will do. Also it wouldn't hurt anything if rtv sealant is also used
zran22 is offline
post #5 of 8 Old 01-25-2013, 12:34 PM
Gearhead
Quoted: 45 Post(s)
I meant to say the on the three-speeds (A131L), the fill on the differential reservoir - it is only filled via the fill port on the side of the differential/transaxle case on the firewall side (like a manual transaxle) - it is not fluid connected to the main transaxle which is filled via the dipstick tube. The transaxle portion holds about 2.5 quarts, the differential will hold about 1.5 quarts.
Different story with the 4-speed autos (A245E) - they are joined together internally - so they share the same reservoir. Fill through the dipstick fill. Holds just about 4 quarts for a drain and refill.
As for the RTV, I agree, won't hurt, but moderation is the key. If you start bolting things up and RTV squeezes out - then that is too much. I personally might smear on a very thin layer on the pan lip to help the gasket "stick" to the pan. Though I've noted that many gasket manufacturers are starting to run a couple of smaller key holes on the pan gasket, usually close to the corners, making RTV unnecessary. They allow you to thread a few bolts up there and hold them in place via friction. That way the gasket won't unfurl as you try and line it up and replace it back on the transaxle.
post #6 of 8 Old 01-26-2013, 02:30 PM
Quoted: 0 Post(s)
Does anyone have the torque specs for the pan and drain bolts? Does 48 in. lb sound right for the pan bolts?
lima is offline
post #7 of 8 Old 01-26-2013, 02:51 PM
Quoted: 48 Post(s)
A131L is 43 in. lb. / A245L shows 48 in. lb
dward3 is offline
post #8 of 8 Old 02-02-2013, 05:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
zran22 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
Back
