Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Head Gasket
Thread: Head Gasket
View Single Post
Old 06-27-2006, 04:51 PM   #14 (permalink)
ToyotaTechGeek
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
adjust the valves. keep them slightly 'tight'. then do the compression test. after that, if there isn't sufficient evidence, then do a 'wet' check. then after that, try a leakdown test.
well, lemme add to this:
were the valves cut? were the guides at least inspected? how about the condition of the seals? how about the valve springs? perform a perfunctory 'test' when you do the adjustment. shake (or try to ) the valves when you get to each one. eyeball the movement of the camshaft and valve/springs when you go to the next stroke. make sure the valve events seem at least 'normal'.also inspect the camshaft for any weird or suspect wear.
ToyotaTechGeek is offline   Reply With Quote
