Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - oxygen censor causing engine check light
View Single Post
Old 07-02-2006, 11:24 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: oxygen censor causing engine check light
"surf" <surfunbear@yahoo.com> wrote in message
news:1151889745.186916.190190@j8g2000cwa.googlegroups.com...
could midas muffler do this kind of work reliably ?
You could do it yourself just as reliably, if not more reliably, using OEM
parts and without having to cut the factory wire harness. Just unplug the
old sensor, unbolt the sensor, reverse the process. If you can change a
spark plug or a spare tire, you can change an O2 sensor, particularly on an
engine that is mounted longitudinally.
Good luck!
Ray O
