2005 Coralla S radio/clock fuse? - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 1Likes
  • 1 Post By hardtopte72
post #1 of 12 Old 01-09-2006, 11:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
This seems to be a question that has come up for others, but from those disscussions I still can not find mine. My cell phone charger came apart in the lighter and blew the fuse in my 2005 Coralla S. I do not have an owners manual and can not find the fuse for the radio/clock/acc plug. It has the OEM radio/cd/tape player. I removed the change slot to the left of the steering wheel and found a 10 and 4 amp fuse, both seemed to be in good shape. I rotated fuses around in the main fuse panel and still can not seem to find the right fuse. Visual inspection of ALL fuses that I have found seem to be fine. If I knew where and what capacity the fuse was this would help greatly. Thanks.
brown279 is offline
post #2 of 12 Old 01-09-2006, 02:51 PM
touringcamry's Avatar
Quoted: 3 Post(s)
Did you check the one labeled dome? Does your dome light work when you open the door? On some Toyotas, the clock radio and dome light were on the same circuit.
2007 Camry 2.4L 5M
touringcamry is offline
post #3 of 12 Old 01-09-2006, 03:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
checked it
Dome light works fine. Just the radio, lighter plug, and clock.
brown279 is offline
post #4 of 12 Old 01-11-2006, 11:51 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I found it: for future folks looking... It is under the lefthand side of the dash between the steering wheel and the door. It is high up and partially obscured by wires running over the top of the panel. The panel is about 1"X4" black with the fuse locations printed on the outside of the panel. The 15AMP fuse marked "CIG" which is the 4th from the left on the bottom row (if you are upside down under the dash) is it. I am happy now and hopefully this may assist someone in the future. Take a flashlight with you to change it.
brown279 is offline
post #5 of 12 Old 11-22-2008, 03:08 PM
Quoted: 0 Post(s)
Thanks!!
@brown279
I had the same exact problem you did, but I kept looking at the wrong fuses. I tried the one you mentioned, and it worked like a charm. You totally saved me a trip to the dealer. Thank you!!
chrishathaway is offline
post #6 of 12 Old 12-22-2008, 10:53 PM
Quoted: 0 Post(s)
Thought you'd want to know, Brown279, I had exact same problem, exact same car/year everything. You saved my butt. Thanks a million!
LardiASL is offline
post #7 of 12 Old 07-30-2014, 05:42 PM
Quoted: 0 Post(s)
fuse for cigarette lighter, radio and clock matrix 2006
I checked the fuse 10 DOME 15A: working well because the door light and interior light on when I opened the door. Only the radio and clokc and cigarette light don't work. I know there was short cicuit when i plugged the broken charger for GPS. Since then the radio, clock and cigarette lighter won't work. Please advise. thx
QLIE is offline
post #8 of 12 Old 07-30-2014, 06:18 PM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 1559 Post(s)
Check the 15A CIG fuse located in the fuse compartment behind the storage door to the left of the steering column.
To access it, simply open the door and pull up at the same angle it's opened at (sort of up and diagonal) and then look at the fuses behind it.
QLIE likes this.
My Toyota List:
1982 Corolla SR-5 1JZGTE M/T
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is online now
post #9 of 12 Old 07-30-2014, 11:47 PM
Quoted: 0 Post(s)
I have Toyota Matrix 2006. I cannot find fuse box you mentioned. I don't see anything where can contain fuses. can you take a picture and send it to me at q-lie@hotmail.com. thx
QLIE is offline
post #10 of 12 Old 08-05-2014, 12:58 AM
04 Corolla CE manual
Quoted: 573 Post(s)
If you look up with your head on the brake pedal, you'll see the long black rectangular fuse box cover (near bottom of photo). Fuse locations are on top of cover. Just pop it off to access fuses. Use the white plastic fuse tool from your engine compartment's fuse box.
This is what's behind left compartment door. Grey flasher relay box is on the left. Fuses are not accessible from here.
invader is offline
post #11 of 12 Old 08-06-2014, 02:57 AM
Quoted: 573 Post(s)
Is that where your fuses are?
invader is offline
post #12 of 12 Old 08-06-2014, 09:46 AM
Toyota Fanatic
Nope. I was mistaken. I confused my 82 Corolla. The 05 has them on the bottom.
My Toyota List:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
