Hello all,
The 2004 Matrix XR w/auto trans has ~165k miles on it. It appears that at least one of the engine/motor/powertrain mounts is in need of replacement. I have been experiencing increasing vibration over the years when stopped in gear while idling and the brake is applied. I figured I might as well start with the right (passenger side) mount, as I have read this is one of the first to go and easy to access.
Hardtopte72 mentions the torque specs for the three 14mm bolts that mount to the passenger side fender apron are 38 ft-lb here http://www.toyotanation.com/forum/1...-drive-belt-tensioner-replacement-w-pics.html and Haynes says to use thread lock and tighten them securely. I assume parts 3 and 5 shown here make up the mount?
What are the torque specs for the other nuts or bolts that attach the mount to the engine?
Thank you in advance!
