Hey everyone I thought I'd post my maintenance schedule (I also made an excel maintenance tracking sheet but can't attach it). 2008 Toyota Corolla LE
· Change oil (SAE 5W-30)
o every 5,000 miles or 6 months
· Rotate tires
· Visually inspect brake linings/drums and brake pads/discs
· Tighten drive shaft bolt
o every 15,000 miles or 1.5 years
· Replace cabin air filter
o every 20,000 miles or 2.5 years
· Replace engine air filter
o every 30,000 miles or 3 years
· Change brake fluid (SAE J1703 or FMVSS No.116 DOT 3)
o Every 30,000 miles or 3 years
· Change power steering fluid (automatic transmission fluid DEXRON 2 or DEXRON 3)
· Change automatic transmission fluid (Toyota Genuine ATF Type T-4, ATF JWS3309 or NWS6500)
· Replace engine coolant (Toyota Super Long Life Coolant, 50% coolant 50% pure water)
o every 100,000 miles or 10 years
· Replace spark plugs (DENSO SK16R11 or NGK IFR5A11 [gap 1.1 mm or 0.043 in])
o every 120,000 miles or 12 years
· Replace wiper blades
o every 6 months
· Wash inside thoroughly
o Every 6 months
· Wax car
o every 3 months (Sunday)
· Spare tire pressure (60 PSI)
o Every 2 months
· Tire pressure (pg. 292 owner’s manual - P195/65R15 89S – 30 PSI)
o Every month
· Wash floor mats, wipe down surfaces, Windex inside windows (rear view), and outside windows, vacuum inside
o Every Month
· Wash outside
o every week
My car has the Weather tech mats. I went based on the owner's manual, if you notice anything off lmk.
Also, does anyone think it would be ok to change the transmission, power steering, and brake fluid every 50,000 miles?
Thanks
· Rotate tires
o every 6 months
o Every 6 months
· Wax car
o Every 2 months
o Every month
o Every Month
· Wash outside
o every week
Thanks
