Removing front speakers in '05 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 13 Old 08-09-2007, 09:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question Removing front speakers in '05 corolla
what are the steps to remove the front speakers in a 2005 corolla?
toyota_rave is offline
post #2 of 13 Old 08-10-2007, 06:18 AM
Whine connoisseur
Quoted: 0 Post(s)
Remove door panel; drill out rivets the hold stock speaker in; remove speaker.
adsaba1969 is offline
post #3 of 13 Old 08-10-2007, 10:20 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
what are the steps to remove the door panel?
post #4 of 13 Old 08-10-2007, 10:49 AM
Quoted: 0 Post(s)
outta curiosity, what are you trying to do?
BlkPaint00 is offline
post #5 of 13 Old 08-10-2007, 07:08 PM
Whine connoisseur
Quoted: 0 Post(s)
1.open the small panel that is behind the handle, remove the screw with a phillips head screwdriver.
2.pop off the piece to the left of the window controls/auto door lock/unlock which is held on by clips (left if you are looking at it)
3.remove the screws
4.pop off the piece with the window/door lock controls (also held on by clips)
5.unplug window controls and door lock controls
6.pop off door panel from the bottom up (door panel is held on by clips)
post #6 of 13 Old 08-12-2007, 03:29 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
any one care to post diagrams of this procedure? it sounds terribly complicated to replace 2 speakers...!
post #7 of 13 Old 08-12-2007, 09:08 AM
Crowbar911's Avatar
Quoted: 0 Post(s)
I learned that My 01's door panels are a bitch to get off.
Whne I got new speakers, I tried to take the door panels off. I was able to get them off, but I had bno clue about putting them back on. So I had to drive down I 295 for about a half hour to get to me best buy for them to re- install.
I hope you have better luck than me.
I would try it. Just be careful and don't break anything, then you can fit it back on.
Crowbar911 is offline
post #8 of 13 Old 08-12-2007, 09:49 AM
Vivir el momento
Quoted: 34 Post(s)
Just be careful you don't break any of the expanding tabs holding the panel in place or cross-threading the screws and you should be fine.
PhatRoyale is offline
post #9 of 13 Old 08-15-2007, 09:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cool
If I could replace the front OR back speakers, which ones are easier to replace and give the most bang for the buck?
Also, would I need to replace the stereo unit to get the most out of the new speakers or would I hear the difference with the new speakers??? are all factory speakers the same? (i.e. paper cone shaped)?
post #10 of 13 Old 08-16-2007, 11:00 AM
Crowbar911's Avatar
Quoted: 0 Post(s)
The back are b y far the easiest to replace. When I did my stereo, I got a new headunit first, and that made the stock speakers sound very good. Then I upgraded My speakers, And is sounded alot better. I personally recomend to get a new headunit first.
post #11 of 13 Old 08-16-2007, 01:39 PM
Vivir el momento
Quoted: 34 Post(s)
why choose?
just do it all at once
post #12 of 13 Old 08-16-2007, 01:46 PM
its a non-prius ha
AzN-BriaN's Avatar
Quoted: 0 Post(s)
Originally Posted by PhatRoyale
why choose?
x2
AzN-BriaN is offline
post #13 of 13 Old 04-12-2008, 11:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well got a new pioneer mp3 headunit and replaced all 4 speakers in my 2005 Corolla with Blaupunkts (2 ways in the front, 4 ways in the rear)... awesome sound... MUCH better than the stock system and speakers!
pain in the _ _ _ to change the speakers... the headunit, I understand... wonder why they build them like that!!!!
my 2000 honda is so much easier to access all the speakers - just pop off the grills and unscrew!!!!
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
