05 Corolla - How to remove rear brake drums - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 14 Old 12-20-2007, 11:29 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
What is the trick to pull rear drums on 2005 Corolla LE ?
Bill
billy bronco is offline
post #2 of 14 Old 12-20-2007, 11:57 AM
Quoted: 0 Post(s)
On the Brake Drum near the center are two opposing threaded bolt holes. Find two bolts the are threaded correctly for bolt holes. Simultaneously screw in both bolts two ratchets work best the drum will usual make a popping sound a it breaks free then slides right off. Don't worry about the popping sound this is due to many times the drum is stuck on the center spindle due to rust and heat.
relliott is offline
post #3 of 14 Old 12-20-2007, 12:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Okay, its like a build in wheel puller, leave it to Toyota - thanks
post #4 of 14 Old 12-20-2007, 02:31 PM
BANNED
Quoted: 0 Post(s)
take a rubber mallet and beat on the front side (hub), that should loosen it
w203 is offline
post #5 of 14 Old 12-20-2007, 05:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The two bolts did the trick, and it was slick! Opened up to find drum blue, musta got pretty hot. Front side of shoe cooked. Will replace both drums and shoes on both sides, wheel cyl look fine.
Can't really see anything causing noise but all new parts should make it go away, there cheap enough, why not.
Thanks
post #6 of 14 Old 12-20-2007, 05:35 PM
Registered User
Raddman's Avatar
Quoted: 0 Post(s)
USA
Check your rear wheel bearings while your doing the brake job...I found a bad one on my corolla that was making a humming sound...It's easy to replace...
Raddman is offline
post #7 of 14 Old 12-20-2007, 07:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My noise is described below, as I responded in another post to someone else who drove with ebrake on:
"When I first bought my 2005 Corolla LE, my wife drove (6K miles) about 20 with the ebrake on, talk about smell - she does this with all my cars.
Ever since (46K miles now) when it is wet out, rain/snow the right rear brake makes this huge grinding and squealing sound as well as locks up. If I drag the brake slightly while driving with the ebrake handle and dry it out it the noise and locking up goes away.
Something about that pad getting wet. I'm wondering if its glazed or has brake fluid on it. I took it to Toyota before warranty was up and they said all looked fine. Of course I didn't tell them what really happend."
post #8 of 14 Old 04-13-2008, 12:32 AM
Quoted: 0 Post(s)
Hi,
Does anyone know what size bolts are needed for these 2 holes? apparently I do not have the correct size in my toolbox and am wondering what size they need to be so that I can get them from OSH or Home Depot...
toyota_rave is offline
post #9 of 14 Old 04-13-2008, 12:35 AM
rwd_3tc
Quoted: 1 Post(s)
Originally Posted by toyota_rave View Post
Hi,
i believe they are 8x1.25mm
1981 Toyota Corolla TE71
1990 Toyota Previa
rwd_3tc is offline
post #10 of 14 Old 04-13-2008, 12:45 AM
Quoted: 0 Post(s)
Thanks for the quick reply.
So does that mean it is 8mm (L) x 1.25mm (W)?
post #11 of 14 Old 04-13-2008, 08:02 PM
Quoted: 0 Post(s)
That means it is an8 MM diameter bolt with a pitch of 1.25, which means that the distance from one thread to the next is 1.25 MM. Common bolt, easy to find.
steve-wis is offline
post #12 of 14 Old 04-13-2008, 11:53 PM
Quoted: 0 Post(s)
Thanks!
Got 2 today from OSH and managed to take apart the rear brake drums to clean and grease the parts...
post #13 of 14 Old 04-14-2008, 12:59 AM
Registered User
Raddman's Avatar
Quoted: 0 Post(s)
USA
Thanks!
Grease what parts?
Raddman is offline
post #14 of 14 Old 04-14-2008, 10:22 PM
Quoted: 0 Post(s)
Grease the springs and parking brake tensioner (basically any moving metal part of the brake system).... was hearing brake noise when applying the brakes... after I cleaned and greased the front discs the noise went away (I'm at 61,000 miles now)... first brake inspection/cleaning (I am the first owner)).
Just did the rears this past weekend to finish the 4 wheels....
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
« Back
