Fuse box location - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 5 Old 02-11-2008, 10:24 PM Thread Starter
The Matrix has you...
Quoted: 0 Post(s)
(Thread Starter)
Question Fuse box location
Where is this 'second fuse box' located? The one in the engine bay is obvious, just to the right of the battery. I cant seem to find the second. According to the manual, its under the steering column with the cluster of wiring. I looked and couldn't find it, though I didn't look long cause its 11 degrees outside and I don't fit well on the floor mats with the doors closed. The reason I'm asking is because I need to replace the stock flasher with one designed for LED bulbs to get rid of hyper flash, and figured it made the most sense if it were located in the fuse box in the engine compartment, but its not.
'03 Matrix XR RIP :'(
PA Firefighter is offline
post #2 of 5 Old 02-12-2008, 12:26 AM
XRS
Quoted: 0 Post(s)
You're in the right area. Just wait for warmer weather I guess.
http://www.bayareamatrix.com/2003Toy...c/relayloc.pdf
See page 2 labelled "Instrument Panel J/B".
Page 5 gives you details.
mistamatrix is offline
post #3 of 5 Old 07-08-2010, 10:31 PM
Quoted: 0 Post(s)
is there a better site to how the location I found nothing helpful
bam85 is offline
post #4 of 5 Old 07-09-2010, 03:39 PM
Senior TN Member
Quoted: 129 Post(s)
Lay on your back on the drivers side floor and look up above the hood release, there is a black cover over the fuse box. You will need a flashlight.
mikered30 is online now
post #5 of 5 Old 08-02-2010, 12:13 PM
Quoted: 0 Post(s)
I need a 2003 Toyota matrix fuse box diagram for under the dash, please!
gtrguy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
