P0031 on Corolla 2005 - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 42 Old 03-30-2008, 06:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I read a DTC P0031 on my Corolla 2005 (OXYGEN SENSOR HEATER CONTROL
CIRCUIT LOW (BANK 1 SENSOR 1)), no other DTC found. I have already inspected/replaced for the following:
1) MAF is OK.
2) Have new O2 sensor
3) Injectors working properly (steady click on idle)
4) PCV valve and hose are ok
5) Replaced with proper spark plugs and gap (0.043")
My problem started with P0171 but after changing the O2 sensor this DTC dissapeared and P0031 showed up, however, my engine struggles on idle.
Please, can anybody help me out??
laramarvin is offline
post #2 of 42 Old 03-30-2008, 07:01 PM
Senior TN Member
Quoted: 129 Post(s)
Originally Posted by laramarvin View Post
I read a DTC P0301 on my Corolla 2005 (misfire on Cyl. 1), no other DTC found. I have already inspected/replaced for the following:
1) MAF is OK.
My problem started with P0171 but after changing the O2 sensor this DTC dissapeared and P0131 showed up, however, my engine struggles on idle.
Do you have code P0131 or not?
When did the P0301 code show up? After you changed the plugs? What kind of plugs did you use? Did you check all of your connections with your coil packs? What did you clean your MAF with?
Check all wiring and connectors that lead to the cylinders, especially the coil packs.
mikered30 is offline
post #3 of 42 Old 03-30-2008, 09:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi, thanks for the quick reply. I'm sorry I posted the wrong DTC, the real DTC is P0031.
It appeared after changing the O2 sensor and my engine now struggles even more than before on idle.
post #4 of 42 Old 03-30-2008, 09:27 PM
Senior TN Member
Quoted: 129 Post(s)
Which O2 sensor did you replace, the front or the back one?
post #5 of 42 Old 03-30-2008, 09:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The front one (before cat.)
post #6 of 42 Old 03-30-2008, 10:31 PM
Senior TN Member
Quoted: 129 Post(s)
Could you put the old plugs back in?
post #7 of 42 Old 03-30-2008, 10:42 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I haven't tried that because I didn't see any difference when I changed them the first time. I replaced them with the proper plugs, denso iridium SK16R11 gap=0.043" as Toyota specs.
post #8 of 42 Old 03-30-2008, 10:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Sorry, If you were talking about the O2 sensor plug, yes, I could. Both sensors (old & new) have the same plug type. It's a 4-wire planar sensor.
post #9 of 42 Old 03-30-2008, 10:56 PM
Senior TN Member
Quoted: 129 Post(s)
Is your car still under warranty?
post #10 of 42 Old 03-30-2008, 11:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No, it is not.
post #11 of 42 Old 03-30-2008, 11:30 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
More info:
The problem started with P0171. I "fix" it replacing the O2 sensor.
After replacement, the P0171 disappeared but a new DTC showed up, the P0031.
There is a difference between old and new plug:
-Old is denso 89467
-New is denso 89465
I'm not sure what the difference is but they look the same. I'm stuck with P0031 now.
Any idea that could help me?
post #12 of 42 Old 04-02-2008, 10:09 PM
rwd_3tc
Quoted: 1 Post(s)
first of all p0171 is a system to lean code. the correct fix for it is a new updated intake manifold gasket not a 02. pm back
1981 Toyota Corolla TE71
1990 Toyota Previa
rwd_3tc is offline
post #13 of 42 Old 04-21-2008, 01:02 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi rwd_3tc,
You were right on the money. I took it to my mechanic and there was a leak on the intake manifold. I heard a vacuum noise but I thought that was normal. Now the engine runs smooth, however, I don't know why but mileage seems to have gone little poor.
Thanks
post #14 of 42 Old 04-28-2008, 11:59 PM
Quoted: 0 Post(s)
What's the difference in the updated gasket? what was wrong with the original? just curious ...my mom has a mystery p0171 ... so far, I've tried Marvel Mystery Oil treatment in gas tank to help clean the injectors. Also cleaned the MAF with electric cleaner. still got the code.
drdd is offline
post #15 of 42 Old 04-29-2008, 05:16 PM
rwd_3tc
Quoted: 1 Post(s)
just take it to the dealership if its still under warranty. if not you can just buy the new intake gasket at the dealership. it will take less than 1 hour if you take your time. its a NEW UPDATED part.
1990 Toyota Previa
rwd_3tc is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
