My Corolla's odometer stopped working at 299999km - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 2Likes
post #1 of 86 Old 11-27-2008, 06:27 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My dad's Corolla's Odometer stopped working at 299999km and it won't move but the trip works, anyone know why???
ericgu22 is offline
post #2 of 86 Old 11-27-2008, 06:48 PM
Quoted: 0 Post(s)
This is a known problem with the 9'th Gen Corolla's. The only cure is an odometer replacement. I couldn't find the TSB, but I found an informative thread on the problem here:
http://www.wheels.ca/article/32130
rsirois is offline
post #3 of 86 Old 11-27-2008, 07:52 PM
Quoted: 0 Post(s)
yea, same with matrix. and toyota isnt going to pay for their defective part .
r0lla5XRS is offline
post #4 of 86 Old 11-27-2008, 08:07 PM
Senior TN Member
Quoted: 51 Post(s)
Vibe is effected too.
So what happens when you go in for inspection? Mileage would not change. In PA, you would be exempt from emissions, and not pay for the emissions sticker.
mikered30 is offline
post #5 of 86 Old 11-27-2008, 08:16 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
This is a defective toyota part, And i will go and solve the problem with my dealer see what they say
ericgu22 is offline
post #6 of 86 Old 11-27-2008, 08:34 PM
Bitter's Avatar
Quoted: 622 Post(s)
could you switch it read in miles maybe? a mile is like twice as long as a silly killo-meter is, so it should take twice as long for the problem to occur right?
wonder if this happens to ones set to read miles at 299,999 miles?
Bitter is offline
post #7 of 86 Old 11-27-2008, 08:35 PM
Quoted: 0 Post(s)
no, can't switch it.
post #8 of 86 Old 11-27-2008, 08:35 PM
Senior TN Member
Quoted: 51 Post(s)
I am not sure if they will solve your problem and likely you will have to pay for a new one, $250 + labor. Ask them what happens at inspection when the odo doesn't change, is that considered odometer fraud? It is a known problem, but not a recall, and by 299,999km you are well out of any warranty.
post #9 of 86 Old 10-10-2012, 06:32 PM
Quoted: 0 Post(s)
toyota should be fixing this they know it is a known manufacture problem. but they turn a blind eye to helping loyal customers
david camarra is offline
post #10 of 86 Old 10-11-2012, 07:52 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 902 Post(s)
This is an almost 4 year old post. And the newest 9th gen Corolla is almost 5 years old. I strongly doubt Toyota cares to replace the cluster on every single 9th Gen sold for something they designed into the cluster.
If you are that worried about it you will need to just buy a new cluster.
My Toyota List:
82 Corolla SR-5 1JZGTE M/T
03 Corolla LE 1ZZFE A/T
05 Corolla CE 1ZZFE M/T
05 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
The Following User Says Thank You to hardtopte72 For This Useful Post:
seeemmiss (06-15-2013)
post #11 of 86 Old 10-11-2012, 08:48 AM
Quoted: 1117 Post(s)
Does the new cluster go past 299,999 KM/Miles?
zythr is offline
post #12 of 86 Old 10-11-2012, 10:48 AM
Now Hiring Co-Drivers
SaGa's Avatar
Quoted: 3 Post(s)
I don't know if Toyota made an update to the cluster by the end of the 9th gen's run, but I'm pretty sure this isn't a defect so much as it's just the maximum mileage that the gauge was designed to reach, just like the old analog meters that were only 5 figures rolling back to all 0s at 100,000 miles or km, only this digital one simply stops reading after 299,999. I doubt a replacement will be any different from the one that's already in there.
There are places that do reprogramming on these newer digital gauges, and that may be a cheaper route than buying a new gauge cluster and better than getting a used one with some random mileage on it that doesn't match yours. I'll have to see if I can find some info, because I know I've seen something about a company that does this before. This way, for example, if your gauge cluster suddenly died, you could buy a new/used one, and have it reprogrammed to match your proper current mileage. If I find it I'll edit this post and paste it in.
-SaGa
'03 CE Auto
SaGa is offline
post #13 of 86 Old 11-11-2012, 12:01 AM
CorollaDave's Avatar
Quoted: 1 Post(s)
Bought my '05 Corolla in June 2005. By June 2009 I had put 299,999 km's on it (I drive a lot). My local dealer replaced it for free. The kick in the pants is that they tell me the replacement odo will also stop at 299,999. That'll be around the beginning of April 2013, so I'll report back. Local dealer says they might replace it again for no charge. If not, guess I'll be using the trip to keep track.
CorollaDave is offline
post #14 of 86 Old 11-11-2012, 12:32 AM
Bitter's Avatar
Quoted: 622 Post(s)
I guess they never planned for people to keep their cars that long or for them to last that long.
Bitter is offline
post #15 of 86 Old 11-11-2012, 08:12 PM
DOHC VTEC
Nusdogg's Avatar
Quoted: 0 Post(s)
Never knew of this problem. Good info!
1.8L 1ZZ-FE VVTi
Nusdogg is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
